All of the knives have bushings inserted in the blades except the Selector. The Selector bushing has a flat spot that is tangential to the axis of blade rotation. This flat allows a slotted blade to slid onto the bushing when the rocker is depressed. However, the bushing must be properly oriented. So it is fixed/molded into the handle.Got ya, and are you using the same bushing for the 186 ? Sorry tiguy for all questions, here's another when tapping titanium do you need special tapping fluid or taps. Thank you again
The 186 came from the factory with 4 #5X40TPI holes tapped in the right handle slab. No Helicoils necessary. The bushings are pretty much the same from knife to knife. They vary slightly in thickness as do the blades. So you want a bushing/blade combination that lets the blade swing freely but has scant sideplay.
The bushings are usually stainless steel or bronze. The lock rockers use the same bushing on the Ti knives although the width isn't as critical as it would be on a blade bushing. Hard to notice sideplay on a rocker.
		 :thumbup:
:thumbup:
