My thanks to Vassili for posting the larger picture and describing the modifications to the GM.
No disrespect intended to you on that but mentioning the modifications that you made to your GW in your post before just "noting" its failure to perform (to your standards) would have saved a lot of speculation and debate.
Absolutely true that it's your GW to modify as you see fit but mentioning that it's a modified GW from the start and providing some more information in the beginning would reduce a lot of what occurred from pages 2 and 3.
I decide to measure actual angle. Thickness at the edge sholders - 4/64". Edge length - 8/64". So angle will be 2 * arcsin( 0.25 ). See math here:
Actual edge angle should be bigger then 30 degree because edge is convexed a little bit.
So this is my drastically altered paper thin edge.
Thanks, Vassili.
...middle aged mathematician...
I just check same way edge on my MS which has factory edge - I did not sharpen it - 1/32" thickness and 1/32" edge lengch (width) - which mean 60 degree angel on the edge.
Thanks, Vassili.
I actually sad that it is not modified, but simple sharpened to 30 degree - thickness of the edge from factory cause it to look so wide, but as I described in my previous post - it is slightly bigger then 30 dergee.
Thanks, Vassili.
mod⋅i⋅fy   /ˈmɒdəˌfaɪ/ Show Spelled Pronunciation [mod-uh-fahy] Show IPA Pronunciation
verb, -fied, -fy⋅ing.
verb (used with object) 1. to change somewhat the form or qualities of; alter partially; amend: to modify a contract.
Not playing a rules lawyer or being finicky, but your definition of modification may be different and the term is subject to interpretation
http://dictionary.reference.com/browse/modified
Changing edge geometry is certainly a modification
It is certainly your right to change your knife as you see fit but it putting it out as a representation of a "failure" or "weakness" also carries the responsibility of noting how you changed it prior to pointing out its perceived (by you) weakness.
The designer and manufacturer of the knife has already addressed your modification.
You bear the responsibility of making the modification and reporting that modification clearly from the beginning. You put it out as a general example by saying you didn't modify it. Your knife was changed and then, it is your opinion based on your modification and is unique in both aspects.
Regards.
I do not want play terminology games here. I think if what you are saying official position of Busse, it should be stated by them directly. Because at leas I expect any knife hold 30 degree edge and if Busse different then it should be some warning - not for 30 degree edges.
And if you insist that resharpening is modification (and it always will change angle to some degree so your quote will be valid (and it will be valid even for using knife I guess - it does change edge does not it?), especially 60 degree Busse angle) then it should be warning - "do not resharpen".
Thanks, Vassili.
This is what happen to my Busse Game Warden Blck/Tan G10
After few minutes on working with this wood
I was trying to get rid of many holes where crickets can hide from my dragon. It was not of course gentle cutting - I use it with force, but using only hands. However this is not steel pipe but wood. Dry wood of course, but you may see damage - areas of depression etc.
...I guess I was not patient enough to wait while it get sharpen back...
This is just an example, but in many cases I notice that Busse get dull relatively quick. Of course it is tough and may be used for steel pipe batoning as Noss4 shows - so to me this is steel you can always relay on and it will not break etc, but in terms of edge holding it is not the best obviously.
Thanks, Vassili.
No, be responsible and forthright about what you do to something before you fault it.
If I thin an edge and it sustains damage it is likely my fault.
Point is, you induced it and then tried to imply that it wouldn't hold an edge.
No where did you mention that you had thinned and modified the edge. You only mentioned it after pressed for more information.
You have still failed to address other posters comments as well.
Regards
Well you can blame in this and that - I do not care. And change your tone you are not my principal and I am not your student.
It seems like we are in agreement that Busse got damaged at 30 degree edge on that wood.
Now if you think that this is unreasonably thin edge then tell what edge you think is proper to INFI, because to me this is something new. To my knowledge 30 degree is standard and usual angle for blade.
Thanks, Vassili
The reprofiled edge on that knife is ridiculously thin and the statments made about INFI, based on this drastically altered edge, are completely irresponsible!!!. . .
If we thought that paper thin edges were the best performance geometry for INFI, we would be putting them on ourselves.
As for edge holding, we are still the only manufacturer to have cut over 2,700 pieces of 1 inch hemp rope in a "LIVE" demonstration at BLADE Show 1999. . . NO other manufacturer has even attempted to duplicate this test.
It's been almost 10 years of waiting. . . .
So, while we're waiting for this to happen. . . .
Let's Drink!!!! :thumbup:
Jerry
Your read of my tonality is an impressive ability.
We are in agreement that you damaged your edge, nothing more. You modified it and therefore you are responsible for the result due to your modification.
I think case and point is made:
Prima facie.
No more. Done.
I asked on a couple other forums and got no responses. I was told this was the place to come. Nice forum BTW.
I am new to the quality knife arena. I have had a Cold Steel Trail Master for years, and recently picked up a Recon Scout. The Recon Scout says made in China which means its time for a new brand of knife.
I am looking for a hard use knife, and want something that will last a life time of abuse. I live in Wyoming, and go to Montana often in wooded areas.
A friend of mine has a new Fehrman Final Judgement with two sheaths for $375 that I am thinking about buying. It is in the same price range as a Busse of the same size so I want to buy once, cry once. I cant afford expensive knives. I am used to have $2000 custom 1911's and Browning Hi Powers, just never high end knives.
All responses welcome, help a noob out.
P.S. If there is something you dont want to post here, feel free to e mail me.
dbltap45acp@hotmail.com
Thanks, Vassili
