But what if the folder is born and identifies with being a fixed blade and wants to transition?
Then a visit to Dr Tig Welder is in order.
I should get some business cards that say that!
Could be it's just trying to make a point. But I'd refer it to a sharp psychiatrist to be on the safe side.But what if the folder is born and identifies with being a fixed blade and wants to transition?
I suppose you could have some kind of weird converting friction folder like so.
If it folds . . . and it does fold . . . it's a folder.
I voted yes. (I'm sure I'll be told it's a piece of art, or that I'm wrong LOL)
I was given this by a friend a little while before he passed away.
https://www.dropbox.com/s/zyt6u5mos8246uo/2015-07-17%2017.08.53.jpg?dl=0
AJ
AJ
Well hrm... that Is both a "folder" while being a fixed blade, I think that it in essence would be considered a fixed blade knife. Primarily since the (main) Blade of the Knife is in a Fixed location relative to the handle.
AJ: Nice piece with a Great amount of history with you attached. My condolences on your loss.
Tldr= blade fixed to handle without intention of movement of said blade = a fixed blade knife.
Yes, I suppose I could use that technicality to say it's really just a fixed-blade. But AJ legitimately opened a back door and I've got to give credit where credit is due.Well hrm... that Is both a "folder" while being a fixed blade, I think that it in essence would be considered a fixed blade knife. Primarily since the (main) Blade of the Knife is in a Fixed location relative to the handle.
OK. Seems as if it hasn't changed the voting much. And I can see both sides of it. Still, hat's off to AJ for coming up with the best contender in this thread. Well done, sir. :thumbup:Though considered a technicality or not, it is everything but the knife that folds.
Folding corkscrew, check
folding file(?), Check
Folding saw, Check
Folding Knife? error 404: file not found
I still would carry one in a heartbeat though.
Edit: if what I called a file is indeed a knife, then that should be considered two separate parts of one knife, a fixed blade With a folding blade, or a folder With a fixed blade.
Since one accompanies the other, it cannot stand anywhere but along side in regards to classification. Being not one blade that is both, but two separate blades that each does their own separate act independent of one another and serves as two individual blades on one knife. Hence, not being a folding fixed blade, but a folding And fixed blade.
A subtle yet significant difference.
Sorry. If it folds . . . and it does fold . . . it's a folder. In fact, it's nothing more than a modified friction folder. But I'll give it "E" for effort.
Folding saw, Check
Edit: if what I called a file is indeed a knife, then that should be considered two separate parts of one knife, a fixed bladed knife With a folding blade, or a folding knife With a fixed blade. Depending on which the owner views as the primary blade, most likely stating the fixed blade as the primary since it would likely be the most used.
