Sorry. If it folds . . . and it does fold . . . it's a folder. In fact, it's nothing more than a modified friction folder. But I'll give it "E" for effort.
Yeah. Based on my lack of clarity, you win too!
I won't change the title of the thread or the poll, but just to get real, let's limit it to a single blade. OK?
Simple. Remove the scales on a fixed blade and what do you have? A fixed-blade. Remove the screw from the handle on brancron's design and what do you have? A folder. Tell me you don't understand the difference.I don't get that. Once in the open position, in what way would it be any different then a fixed blade with removable scales?
You're kidding. If this single blade is designed to fold, it's a folder. If this single blade is in fixed-position and it's not designed to fold, it's a fixed-blade.Ok, quick clarification please, can this single Blade Fold or is it Fixed in position?
Remove one screw from the scales of a survive 3.5 and rotate the scales to cover the blade. If there was a mechanism to hold it in that position there would effectively be no difference. Tell me you don't understand what a 180 degree rotation is.Simple. Remove the scales on a fixed blade and what do you have? A fixed-blade. Remove the screw from the handle on brancron's design and what do you have? A folder. Tell me you don't understand the difference.
Nice try. But you're clutching at straws. A Survive 3.5 isn't designed to operate that way, is it?Remove one screw from the scales of a survive 3.5 and rotate the scales to cover the blade. If there was a mechanism to hold it in that position there would effectively be no difference. Tell me you don't understand what a 180 degree rotation is.Or is your sticking point tang size?
So you're going with a literal definition. Okay. A knife folds open and then the blade is fixed in place with a screw. It's a fixed bladed knife at that point. Pull the screw at and it's no longer fixed and can now fold. It's now a folder.Nice try. But you're clutching at straws. A Survive 3.5 isn't designed to operate that way, is it?
One more time. If the blade is designed to fold, it's a folder. If the blade is in fixed-position and it's not designed to fold, it's a fixed-blade.
No, it's not. If a pin or a screw can be removed from a fixed-blade knife and the knife is then designed to operate like a folder, it was a folder all along. Why? Because a REAL fixed-blade knife doesn't fold . . . EVER. Now are you done?So you're going with a literal definition. Okay. A knife folds open and then the blade is fixed in place with a screw. It's a fixed bladed knife at that point. Pull the screw at and it's no longer fixed and can now fold. It's now a folder.
No, it's not. If a pin or a screw can be removed from a fixed-blade knife and the knife is then designed to operate like a folder, it was a folder all along. And fixed-blade knives don't fold . . . EVER. Now are you done?
I asked this earlier...
But what about a modified balisong in which only the bottom part of the handle moves, and the top part of the handle is fixed with the blade (via full tang)?
Then, the bottom part of the handle is free to move up to cover the blade, or the blade can pivot relative to and towards the stationary bottom handle position.
That way, the entire fixed blade rotates into the handle.
Or, a fixed blade with an exposable full tang that pivots around the center (at the handle) to 180 degrees to secure itself in the opening of the handle's bottom.
At either open or closed position, they lock securely into place.
They're technically fixed blades that fold, right?
Ataboy! :thumbup:With this silly semantics game. Yup.![]()
Is the blade folding into the handle, is the the handle folding around the blade.
Link me to what you're talking about and let me take a look.
Well hrm... that Is both a "folder" while being a fixed blade, I think that it in essence would be considered a fixed blade knife. Primarily since the (main) Blade of the Knife is in a Fixed location relative to the handle.
AJ: Nice piece with a Great amount of history with you attached. My condolences on your loss.
Tldr= blade fixed to handle without intention of movement of said blade = a fixed blade knife.
