BBLFKYou are super correct, I was still waking up lol
BBL BFK lol
Dude is seriously going to impale himself and bleed out on livestream one day.I also like JOEX. and he knows there's a trade off between cutting ability, and break ability, It's just way more entertaining to watch him break both knives and body at the same time.
Didn't this guy break every knife he tested so far? I mean if the new extra thick CPK will survive without breaking then it would the first one so far![]()
The BFK falls into that "when you weren't expecting it" group for me, but not because I wasn't expecting it to break (but of course I was hoping). The swing that finally broke it seemed kinda half-assed compared to the others...just a little wrist flick.No there are several he was unable to break. The ones I have seen so far are the Hultafors GK, the Mora Robust Pro, the Work Tuff Gear Ares (which split the brick), the Creely Folklore Beast, the Messerfeiber Survival Bushcraft Cavusch 2.0, the Cold Steel SR1 Lite, the Cold Steel Black Bear Bowie, and I’m sure there are others but I haven’t seen all the videos since there are a lot of them. Some didn’t break when you thought they would, others broke when you weren’t expecting it, and still others failed spectacularly that the test was over in a matter of minutes. The extremes of the bell curve make it really interesting. Like…a Mora Robust Pro? Really? But it survived, he couldn’t kill it. And he’s tested a lot of Moras, and all the rest bit the dust. The Garberg came real close.
Joe's destruction of the TRC Apocalypse in Elmax stands a notable example to me. 6mm thick, and the edge started to chip away like tempered glass once it started, then it shattered half way down the tang. Some really bad head treat on that knife I think.
Same. If it had survived, I would not have been surprised. The surprise was more that it broke than if it had survived, but it is plausible that there was already a big fracture that couldn’t be seen, and that last little bump did it. That happened with the Tops Operator 7, but he was able to catch it before total separation. That was at the brick.
That is why I was asking if there is any mitigation of stress risers that can be considered in a blade design that would help avoid a total blade failure resulting from the edge chipping. Maybe it is just a fact of life when talking about knifes with high edge retention. I think Nathan made some good points about toughness vs durability. It makes sense that if an edge mashes down, it may provide a dampening effect on harder edge stress risers at the expense of a more durable edge, or higher edge retention. So it begs the question…is there a knife steel or process that allows the edge to mash/soften instead of break/chip/crack, but it just takes more effort to get to that point?
View attachment 2669385View attachment 2669386View attachment 2669387
Yeah it took pretty serious edge damage, in the concrete block I think, which is where the crack propagated from.
Our edge thickness and edge angle is thinner than most and it ended up being the failure point for this particular blade.
I'm making him a new blade to tryout that's thicker and more obtuse, more like other makers knives, and I expect it won't have that same failure mode.
He did beat on that pole for quite a while before it finally broke. My guess is there was a crack that was working its way up and it finally let go.
Our knives are pretty tough, but our focus is on durability in rough use and a hard strong edge is more durable than a soft mushy one. We are pursuing edge retention and high performance, and are not solely focused on just toughness. I felt his test demonstrated a pretty insane level of toughness for a knife of this type and I was satisfied with the outcome, but for folks who want to see a knife not break, the knife I'm sending him is a little bit more stout and is probably going to do a little better on this particular test.
Covering his face is fine (for whatever reasons), but I don't get the gas mask? Got to be a better choice that still hides his face while providing protection, better vision, and better audio clarity.I wouldn’t send that guy anything except all the boogers you had left over from the bfk sale. I didn’t watch all the videos but my issue is, why do cover your face for a review. It doesn’t appear for safety reasons and if he’s a member of some special forces don’t wear that uniform. All the knives are setup to fail, it’s not if it fails but when. The bfk for the size, profile and weight did the best.
If it makes you feel any better, I haven't seen any of his videos and only heard of him hereabouts recently after some sort of brouhaha or other which, frankly, I know little about and don't care to know.I wouldn’t send that guy anything except all the boogers you had left over from the bfk sale. I didn’t watch all the videos but my issue is, why do cover your face for a review. It doesn’t appear for safety reasons and if he’s a member of some special forces don’t wear that uniform. All the knives are setup to fail, it’s not if it fails but when. The bfk for the size, profile and weight did the best.
I think it was the steel. As N690, people insist in using it in "hard use knives". Unless it's a slicer, those steels shouldn't be used in the type of knives they are used.
