- May 14, 2018
Thank you, David.Thanks yours is very nice as well.
I may still order a new one in Yellow.I was thinking about buying a new one
I have had a couple knives with proud springs but also noticeably downward canted blades. In those cases I found the back square of the tang was hitting the spring before it was flat against the tang.so for a spring to be flush closed and open the front and back of the tang has to be equidistant from the pivot hole. If I had to guess I would say the pattern die for the secondary features a pivot hole that isn’t centered. That might drive me to get the single blade version...
I was looking at my slim trapper that exhibits both those traits and I’d had a similar thought- I’m going to give it a try!I have had a couple knives with proud springs but also noticeably downward canted blades. In those cases I found the back square of the tang was hitting the spring before it was flat against the tang. View attachment 1501257
Filing it cured both the proud spring and the canted blade, may not be the case with these however. Either way with how the bolster is would make filing it a difficult task I believe.
I'll give the same advice I seen someone here post about filing kicks, go slow and check oftenI was looking at my slim trapper that exhibits both those traits and I’d had a similar thought- I’m going to give it a try!
Can't answer your question, but Queen/Schatt & Morgan made them both ways in addition to single blades.Does anyone here know anything about the history of, or the reason for, two different styles of 2-bladed copperhead patterns? Case copperheads usually have a big blade (clip or wharncliffe) and a smaller pen blade. But Böker copperheads usually have two big blades (clip and skinner). I'm curious about the difference.
- GT
As it stands, I'll be grabbing one of those peach seed jigged, amber bone CV versions the moment CollectorKnives drops them. With any luck that'll be March or April right when the baby is due. Dad's deserve a "push present" (apparently that's a thing now) too right?
J jsdistin What do you think about these "proud-when-open" springs?
Is that something you could fix by filing off the tang while it was disassembled?
Does blade play require re-dimensioning the thickness of the spring, or is it as simple as tightening the joint?
regarding the knife pattern, this is one of the nicer patterns, and it looks well conceived. If it's a matter of execution I wouldn't mind having someone make it perfect. Those clip points look great, and the pen blades look sizable too. it's the only thing that's really keeping me from pulling the trigger.
Oops, blade wobble is most likely as simple as peening the the joint tighter and then finding the sweet spot between free movement and wobble. Sometimes it is a bigger issue that needs to be addressed like a spring that’s thicker than the blade or a bent spring or a tang that is thicker at one end than the other. As far as the back spring being proud in these I hate to say it but I would consider getting more than one and returning the inferior ones. A proud spring usually doesn’t bother me though it means the spring is providing more tension making the blade less likely to close accidentally.J jsdistin What do you think about these "proud-when-open" springs?
Thanks for that illustration.
I didn't have the success I typically do in crinking the main blade........ I got it to move a bit but it still lightly touches the liner..... Possibly the tang is harder than normal??.... I'm going to leave well enough alone....... Maybe next time I'm going through Bradford I'll stop in and see if they can give it a quickie crink job.......
