- Feb 28, 2011
I solved that by not having kids.
Some people want kids...I wanted knives.
Good lord, yes. I'm not spamming up the countryside with little genetic copies of myself. More knives, indeed.
It was mentioned how, in example, 3V can be brought thinner than 1095 for equal durability and so could be used to make knives like ESEEs better, and how many knives in higher end steels are not offered in geometries that actually highlight that steel's advantages. I would like to further point out that most knives of more mundane steels are not offered in geometries that highlight their performance either. The fact that people so commonly rave about Moras as being awesome slicers ought to tell you something. Scandi grinds are literally the worst slicing geometry you can have for a given stock thickness and edge angle, so if those are slicing so much better than what these users have experienced...and knives like Opinels and Douk-Douks will slice circles around most modern "tactical" knives despite being made from really quite basic steel. The stuff in Douk-Douks is really only equivalent to something like 1070.
Cardboard absolutely destroys 1095. Just doesn't have the carbide content to keep up with the abrasive nature of the material. I could get by with 1095, but I could also get by without a knife at all, so that argument seems more than a little silly. You're a big fan of ESEE and that's all good, but if I tried to use 1095 at Hrc 55 for all my daily cutting tasks I would be sharpening multiple times per day. Fairly quickly, I would need to regrind the blade when the constant sharpening pushed the edge up into the primary grind. Do that a few times, and I need to toss the knife and get a new one as ESEE comes with relatively obtuse geometry to begin with and now I've made it significantly worse.
On the other hand, for my hunting and camping use 1095 or 420HC are more than good enough. 3V is better and makes my life a bit easier, so I use it more often, but I would be quite content with 1095.
The point of my rant is that needs are complicated. It's easy to argue I don't need anything more than 1095 at work, but it would significantly slow me down and be much more frustrating than a highly wear resistant steel, so my desire for those is more than just want. Grey areas make things confusing and arguments about need tend to pretend those don't exist.
I agree for the most part, buy for its intended use. However, a utility knife would be a better option for excessive cardboard cutting imo(from a financial standpoint especially). So would a number of other steels over 3V or 1095 which both don't have great wear resistance and are more known for their toughness.
I was more joking then insinuating dude and I am glad you are happy
On a side note, I don't know if It is good or bad that there aren't more stabbiess running around. Check that, "needed" or "wanted". I want tiny stabby babies running around but I don't know if they are needed....no, they are...
3V nice and thin would do great. And cardboard dulls utility knives just as fast as it does 1095. I'd only replace sharpening with swapping out the razor. Not an improvement.
I didn't say I was happy. You have strange way of interpreting what others say.
Sure would but, blade knife blades are like 100 for $20, where as 3V starts at around $100 for one. From a financial standpoint there is a clear winner.
P. S. Why are you paying for your own blades at work? And, why are you cutting so much cardboard?
Enjoying comedy and happiness usually go hand in hand lol. Maybe I have been doing it wrong? Lol.
I don't exactly know how to answer that one other then suggesting you look into rehab or possibly asking what your taking so I can try it lol?
I own a business, so the boss buys all my knives for me. I cut cardboard because we get multiple shipments per day and have limited space to dispose of it. You're also discounting the sunk time it takes to sharpen or to swap blades. If I spend 5 or 10 minutes per day doing either, a blade with better wear resistance will pay for itself within a few months.
I see. I obviously don't know your exact circumstances but, might I suggest that getting a cardboard bin rental out back might be cheaper then expensive knives, sharpening, the labour involved, disposal time/fees, exc. And, afford you more space in your shop. All the shops I have worked at have had one. A super steel K if just doesn't strike me as the most efficient option.
I see. I obviously don't know your exact circumstances but, might I suggest that getting a cardboard bin rental out back might be cheaper then expensive knives, sharpening, the labour involved, disposal time/fees, exc. And, afford you more space in your shop. All the shops I have worked at have had one. A super steel knife just doesn't strike me as the most efficient option but, that's up to you.
You have clearly missed the point.
Not funny anymore. Calling me a drug addict and asking for drugs on the internet? What is wrong with you.
JK. But seriously stop using lol. It is stupid.
Insipid. You are on your own here boss. Seems he is not getting why this is BFC.
That's a recursive cost, so the initial investment might be cheaper, but it will rapidly become much more expensive. Particularly when steels with much greater abrasion resistance than 3V are available for around $100.
Sharpening takes time and time is money but, to each their own.
