- Apr 27, 2007
Lycosa could be right...never lose hope...Thx Izan!!Izan---Your Post could end this INSANE Thread.
Tnx.
Tnx.
until noss duplicates his test on more project 1s, it remains unscientific.
vassili still doesn't grasp what constitutes a scientific test so i can give some examples of questions that could be answered by a truly scientific test. and this is leaving out the fact that its performed only on an individual knife
1 what is the EXACT force of the blow that broke the knife?
2 EXACTLY when did the knife's structural integrity first beging to be compromised, even at the invisible level?
3 what was the temperature in the room?
4 EXACTLY where on the knife did each blow fall?
i could go on. the tests don't answer questions like that. they just let you know that if you hit a knife like so, it breaks. that is extremely general information not the kind one would get from a scientific test.
also vass says that since this is a "new science" that we are still in the data-gathering stage and insinuates that somehow, the scientific method does not apply when gatherind new information. this again indicates that you are unfamiliar with the terms of science. we don't reinvent the wheel any time we attempt to learn something new; the method is always the same.
again, i must AGAIN point out that this is all irrelevant, because these were not intended to be scientific tests in the first place, but rather demonstrations, field test, or garden-variety consumer reports.
Im sorry if this has been already mentioned but the film appered to show the hammer as it hit the back of the knife just in front of the handle and not on the area of the blade that was in contact with the wood. Any chance that was the reson or part of the reson the blade broke?
Can you give exact time.
He started at
5:45 - perfect batoning according to that pdf. You may see no shaking on handle.
5:52 - same perfect batoning edge flat on wood no shaking on handle.
5:56 - same - may be some minor shaking at the begining - but not at all as in "bad example" from that document. And most likely because entire set up shaked.
6:04 - perfect.
6:07 - perfect.
Can you just give exact point of time where you see him doing this wrong?
Thanks, Vassili.
First, I think it is reasonable to say that science is not exact, everybody deals with tolerances. If you were using a machine you could get away with saying that you hit the same spot within a few hundredths of an inch. Noss performs within the tolerances of "the back of the blade". It's a pretty wide tolerance, but you could make the argument that he is operating under the same principles.
To take it a step further. If Noss were to find some machine that measures shock, and hit it with his hammer a few times, we could even get an average for how hard he hits a knife. Or at least he could get a feel for how hard the different blows are, giving an approximate amount of force within given tolorances.
I specifically focused on the knife as it broke, both times you can see what went wrong. Like I said, he doesn't do it wrong all the time, but it was enough to get these blades to break. I'm fine with Noss being little sloppy (I would be too), realistically not many people will anyway, thus it's such a common way to break a knife, and a reasonable test IMO.
I think the flak comes from you saying that you have the math in your testing when in actuality, there is very little math. Actually, there's no math. If there's math, show it.
But I guess that's why some of us go into a science field, while others go into a liberal arts field. That's no attack to anyone. It's another way of saying different strokes for different folks.
One thing can be argued. People like numbers. 0 - 60 mph times for those crazy speed freaks. Torque numbers for those that like to haul stuff in their pick ups. MPG for those that like to get the most out of a tank of gas. Ghz for those that like a powerful computer. F# for those that like precision photography. The list goes on.
I will say this. Your vids are enjoyable to watch for me, but to me it's just a spectacle.
Assuming there is a bad hit involved in the CR knives tests then I wonder how other knives would fare if subjected to similar 'bad' blows.
I have a feeling a Busse will be at least 10x more resistant (meaning takes up 10x more blows) of such blows. Actually I suspect most other knives could handle more than the CR knife can take.
I like what Izan said, good points. Something is definately wrong with CR's FBs and instead of over analyzing on the correctness of Noss' vids perhaps we should acknowledge that there is definitely room for improvement in the CR's knives.
Hi Vassili. The hit I mention is the last one. It look like the hammer hit between the front handle of the knife and where the knife was on the wood. If he can slow down the film it will be better to see.
You're the emperoralso some guy said that trial and error is the "oldest scientific method" or something. ummm...if you want to get extremely reductionist, i guess i know what you're getting at. but it's not scientific method, it just, well, trial and error.
http://www.utexas.edu/courses/bio301d/Topics/Nonscientists/Text.html said:In the simplest terms, common uses of the scientific method involve trial and error. Consider automobile repair. Every weekend handyman, and every high school student with a passing interest in autos knows about the method of trial and error. Your car is starting to run poorly, and you take matters into your own hands in an attempt to fix it. The first step is to guess the nature of the problem (your model). Acting on your hunch, you proceed to exchange a part, adjust a setting, or replace a fluid, and then see if the car runs better. If your initial guess is incorrect and the car is not improved, you revise your guess, make another adjustment, and once again test the car. With patience and enough guesses, this process will often result in a operable car. However, depending on one's expertise, quite a few trials and errors may be required before achieving anything remotely resembling success.
fuck, just to put this tiresome thing to arrest, let's not even call it the standard definition. let's just say you have a different idea of science than i do. want to leave it at that? or do you want to keep this going?
http://www.utexas.edu/courses/bio301d/Topics/Nonscientists/Text.html said:The methods scientists use to evaluate and improve models are very similar to the method of trial and error, and are the subject of this chapter. You may be reluctant to think that the bungling process of trial and error is tantamount to the scientific method, if only because science is so often shrouded in sophistication and jargon. Yet there is no fundamental difference. It might seem that scientists start with a more detailed understanding of their problem than the weekend car mechanic, but in fact most scientific inquiries have humble and ignorant beginnings. Progress can occur just as assuredly via trial and error as in traditional science, and the scientist isn't guaranteed of success any more than is the handyman: witness the failure to develop a vaccine for AIDS. One of the themes of this book/course is that the scientific method is fundamentally the same as these simple exercises that most people perform many times in their lives.
