Spats McGee
- Jun 6, 2019
No. I just rinse mine off.
Is it a pain to get all the grounds out first in the trash? That’s always been my hold off on buying a French pressNo. I just rinse mine off.
No. I pour the grounds out through a small sieve, so I don’t dump them down the disposal. I dump them in the trash. I rinse the basket/filter under running water and just give it a hand wipe to knock of any grounds stuck to it.Is it a pain to get all the grounds out first in the trash? That’s always been my hold off on buying a French press
The B&W Chelbesa hydro washed has turned into a completely different coffee after letting it set for a few days. It’s still under a week off roast. Definitely has potential
Normally it’s about a week or so before I get to a new bag. Shipping usually takes that long to me. B&W is in North Carolina so not got to me real quick, plus they’re light roasts. I normally stick to medium and medium/light. I got impatient and went right for it.
I haven't found a huge taste difference with paper vs mesh as long as you rinse the paper first so it absorbs less coffee. I do feel like it's easier to get better results from immersion brewing like a french press or clever dripper than percolation. Cleaning mesh filters isn't hard, just less convenient than paper.
Does a metal filter - mainly French press - create a headache for cleaning up?
Gotcha. I’ve gotten lazy and used to just picking up the paper filter and throwing it out, end of clean up. Or popping it out with the Aeropress. I may pick a French press up one day just to give it a shot.No, just an extra step or two depending on your situation. Grinding coarse, such as with a conical burr grinder, is important for consistent extraction and also makes handling the waste easier.
Two things can be handy for clean-up. First is your wooden spoon or stir. (You can use metal with care but wood is recommended for the beaker.) Grinds go in first, then hot water, then stir to break up the mass and circulate it. Then cover for the allotted time and right before pressing, it gets one more stir. After you've poured off the coffee and the grinds have cooled, you can invert the beaker over the trash (with a finger over the rim if it is the kind that can slide out of the holder) and use your wooden stir tool to scrape out the bulk of the wet grinds.
The second thing is an ordinary butter knife, preferably one that is already waiting for a wash. I don't completely disassemble the press every time I use it, just when I feel like a deep clean. So any other time, I run the butter knife between the screen and the metal holder where grinds tend to get stuck. Do this under running water, and then wash with unscented dish soap and a scrubby like anything else. (If you are very worried about grinds going down the drain, do the first part over the beaker and then pour it outside or wherever.) Coffee oils can still accumulate around the screw attachment so every once in a while, depending on frequency of use, it gets taken apart for a full cleaning.
Depends on the person. I found it a hassle to clean my French press. Other folks maybe not so much.Does a metal filter - mainly French press - create a headache for cleaning up?
Even with immersion brewing I’ve had better results with a finer grind. Aeropress I usually go finer than pourover and with clever dripper I vary between the two. I’ve got a flat burr electric grinder and a conical hand grinder. I know a lot of people have a preference on burrs but I can’t tell a world of difference between them in filter coffee
... It is well established that paper filters trap a lot of coffee's essential oils. That is flavor. Yes, there is also evidence that Cafestol can increase bad cholestrerol levels. Not a problem for me. Cholesterol is mostly genetics, and I am blessed with good genes for cholesterol. Give me the flavor.
I’m drinking their Boji Bonde right now, it’s a Ethiopian carbonic maceration. Pretty good. I’ve got the Guatemalan that I haven’t opened yet as well. Let me know about the Bale Mountain, if it’s still available when I buy some more I’ll pick it up if it’s goodI'm on the Corvus Bandwagon also, starting Monday
View attachment 1764805.
That prismo looks interesting. Hadn't heard of it before and it's surprisingly inexpensive for a Fellow product.View attachment 1760873New Guatemalan and a new toy arrived today
