Not sure if your doc has mentioned this before, but just a little FYI (since I'm sure we're all trying to do what we can to avoid clinics/hospitals like theplagueCovid-19), if you're having a strong allergic reaction, taking an H2 blocker concurrently with the Benadryl, has a synergistic effect that increases the efficacy.
H2 blockers = famotidine (Pepcid), ranitidine (Zantac), Cimetidine (Tagamet).
https://pubmed.ncbi.nlm.nih.gov/19052407/
https://jamanetwork.com/journals/jamadermatology/article-abstract/542221
One possible reason why the Hydroxychloroquine results have been kind of all over the place, is due to insufficient supply, and a difference in administering it.Till a tried, tested, effective and approved vaccine is developed, distributed and administered to the public at large, a concoction of effective therapeutic meds will probably be the only other alternative much like the HIV virus which to this date, does not have such vaccine. So far, Hydroxychloroquine on its own has not shown to be the elixir.
Just a heads up, folks:
Looks like at least 10 (and counting) US meat packing plants have shutdown (or are shutting down) due to Covid-19 outbreaks.
If you're running low on meat, you might want to make a resupply run soon.
This goes for our Canadian brethren too:
https://www.cbc.ca/news/canada/calgary/meat-packing-covid-1.5533574
Good recommendations.It goes without saying to be very careful as to where you get your (mis)information from, let alone the kinda (mis)information which can literally lead to life or death consequences.
One great litmus test, at least for me, is to verify as to whether the information comes from a vetted and verifiable source and If so, there are two different steams of such information but crucially and critically, the original and the main source of that information OUGHT NOT be open to reader comments. FULL STOP. PERIOD!
If you see any kind of research paper whereby it allows readers to make comments, run as far away and as quickly away as possible, do not get contaminated by such info and if you do, please do not spread (as an example, the anti-vaxxer crowd is typically very vulnerable and susceptible to this simple BS detector test of mine) The only place where a scientific paper should be debated and critically commented upon, should be among the other expert scientists of that field in the right venue which is usually a symposium with the bonafides.
Ha! Yes, one of the local businesses we’ve been trying to help support, makes really high quality ice cream, sourdough bread, and chicken (vegetarian, also) pot pies. I’m afraid, I may be started on the path toward that second picture, if I don’t rein it in a bit.Mike
Probably because you're not laying around with your boobs out...... I've lost weight...
