Cliff Stamp
BANNED
- Oct 5, 1998
As noted, smaller branches can be soaked/frozen through, you need thicker wood to get dry heartwood. And as noted, my knife would not break because I would be carring a suitable one.4 Ranges said:I'd rather cut smaller branches that won't dull my knife
Now if I had to use a friends and all he had was one with shody QC then I'd face a difficult decision. Deciding to chance the knife would depend on just how cold it was, chance of rescue, ability to walk out, etc. . Having a usable knife and being frozen the next day doesn't do you much good.
In such a situation what I would do is work into the knife gradually splitting it piece by piece, avoiding knots, and going slow and using wedges carved before hand with the knife. All of this however takes time and energy so again, buy better tools.
Of course there is always a chance that knives break, I have seen high end custom knives get ruined just chopping through a piece of wood, no batoning or hammering just chopping, and that is why you buy such knives, you can't argue a 1/4" camp bowie should not be used to chop wood.
By the way, lots of axes will fail on that class of wood as well, as will many khukuris and other large chopping bowies. I have seen numerous examples of all of them, and as noted, simple $5 Mora's that easily handle it.
I use knives to descruction, more so than most mainly because I don't pay for a lot of them, so it doesn't cost me anything, and second this gives me a reputation which keeps a lot of the junk at bay, so when I go buy a knife a lot of the hype falls away.Franco G said:do you mean you test a particular knife, say, by abusing it enough to get a confidence, or, do you test a particular type of knife, e.g., you test Camp Tramp and say Camp Tramp knives are OK.
That being said, for the knives I depend on, often ones I buy another of, I will redo some of the non destructive tests, meaning the things that should not have damaged if it the quality is as good as the previous ones. Just because a knife did well doesn't mean the QC isn't in the toilet on the next one, no maker can guarantee 100% perfection.
In addition I never depend on just one tool and always have fallbacks, like I always carry a SAK + saw and decent multitool, solid folder and have multiple fixed blades and folding saws + an axe in my car, and a solid fixed blade on me just out walking around and always more than one when seriously hiking.
If I actually expect anything probable or serious use, I usually have a similar amount of knives as the bald dude on Lost. I have not used the Ratweiler, but the guard is much more pronounced than on the Safari Skinner and that is very secure when stabbing.
As for wood and small branches, I have seen such wood fail to light after being soaked in gas, the gas burnt off and the wood remained. You first need to supply enough heat to phase change the water to liquid and then vaporize it. This is a lot because the heat capacity and heat of fusion for water are both high, then you have to heat the wood up to the ignition point all while the air is trying to suck it back down, this is much harder at -30 than at room temperature..
The question remains why buy inferior tools. Yes there are lots of knives that will break under the above conditions, just like there are lots of ropes that will break if you try to climb with them, and lots of boots that will fall apart if you go hiking with them. So buy gear that can stand the intended use. If a $5 Mora can stand it, its kind of silly to call it abusive - again unless its stainless, or you have a radically different knife like a S90V fillet blade, but the RS is a *very* robust design.
-Cliff
