As you may learn from my test description I am not measuring force required to cut rope and so edge thickness does not matter (as well as many other factors I eliminated). I measure sharpness by cotton thread and it is thinner then any edge. So I thought this through five years ago and toke all that into account, so I can compare blade with different edge thickness, unlike you.
I would agree that in your test you may test not steel property but edge thickness. But this is not only factor which affect your results and make them random - I already mention that you cutting wooden base not only rope, and many other things.
I have several Doziers in my collection and they all have different edge thickness depends on model:
I have on my Doziers 3/64", 1/32", 1/32", 1/64"
and on Buck 110 - 1/32
and on Manix II CTS-XHP - 1/32"
and on BM710 M2 - 1/32"
and BM710 M390 - 1/64".
just measured it.
So as you may see this is not an issue, at least for my tests. BM710 M390 with 1/64" did not out cut Dozier KS7 with 3 times thicker edge as well as many other knives.
Thanks, Vassili.
I read through this thread and was surprised at how little discussion there was of actual experience with the steel. Does XHP give better edge retention, toughness and strength than D2, or is there a sacrifice somewhere? Have people used it much in the field?
I find it hard to compare steels from practical use in many cases. The "identical" steel can vary in properties from knife to knife from the same maker. I have a Fallkniven TK3 and U2. The core steel in the U2 is not anywhere near the same in edge holding as the steel in my TK3.
I have used lots of 440C in the kitchen and fishing. M2 is far better than the 440c in edge holding in the Kitchen, as is VG10. I can't tell the difference between my M2 knives (Gerbers) and my Sperderco VG10 in the kitchen, since both steels hold an edge for a really long time.
In fishing, I have not been happy with 440C - the steel seems to lose an edge far too quickly in cutting through bone and scales. I hope to get better performance from VG10 in this role. My 440C knives in the kitchen (Gerbers) seem to hold an edge about as well as some old high carbon steel knives that I have.
Vassili,
I was talking about one type of job falling under the umbrella topic of wear resistance and gave an example but you changed the subject, then tried to say you used more steels than I did. It's difficult keeping up a civil dialog under these circumstances. We're not in a contest of any sort, nor do you know what knives I have used at home for anything but one project with a carpet I posted about. Please try to stay on the subject and don't feel you need to defend your work. Your work is excellent, but it only covers a small area of one part of one of the big three knife steel attributes.
The fact is that the demands on a knife blade and steel are different cutting up old, dirty carpets from the demands in your testing, or your drywall and sprinkles cutting jobs.
One job ( carpet) needs one type of attribute from a steel, the next job calls for something completely different( measured weights cutting twine after dulling on half inch rope). These are still under the unbrella topic of wear resistance which is only one of the three attributes by which we gauge our steel needs. We could come up with other tests to explore even other aspects of "wear resistance" and probably eventually will.
Do you claim a crescent wrench is better than a screwdriver or are they just different tools for different jobs?
That's what steels are to me. S90V isn't my favorite steel, nor do I claim any kind of overall superiority for it other than with the quantifier that that knife was better at that particular job on that day.
Any other claims can't be proven. Not in the 40 years I've been collecting knives have I seen an argument proven about any steels superiority. The best we can hope for is a steel or knife being the best at any given task. The resources to do otherwise are beyond most of us.
I've seen pictures you've posted of this knife. It's a beautiful knife and it looks pretty comfortable to work with. I've never tried that steel, with it, and T1 being the only ones on your list I don't have personal experience with. Also, I currently don't own a 10V knife. I do have a couple not on your list from your testing webpage.
Vacuum Arc Remelting ( VAR) is also used on BG42, amongst other steels. It's not magic, but it does help get some of the impurities out. Some metals like Titanium have to be VAR'ed 2 or 3 times.
I believe Carpenter is going to produce a version of BG42 ( CTS B75 ?) that's been both VAR'ed, and using the powder process. BG42 normally is an ingot steel. It's one I'm looking forward to trying as it's extremely clean, but with the PM advantages.
I've always enjoyed BG42 though in general stainless steels aren't my favorites and hope this works out. Things are looking up for us steel junkies.
Regards, Joe/raleigh
more tests, especially different types is the best way to get the overall picture of a steels performance. keep up the good work everyone and lets hope we see more of these high-end steels being offered (so we can all test them).
I will be updating my list, adding a lot more steels shortly.
Will you note the model and manufacturer? :thumbup:
As long as they are within specs I won't, something different and I will.
Like where your test is limited to push cutting the manila rope of one type, which is very unrelated to the job he described, so I am not quite sure how do you make conclusion that you have ANY evidence related to what Mastiff said....You provide you evidence saying that you tested it using four steel on house project. I think this experience you had is limited to this four steels and in my case for wider range of steels CPM S90V was not best so I have evidence that your theory has nothing to do with reality.
Where here any logical flaw?
Well, yeah, if you test with different sharpness, and edge thickness few times wider than competitor, no wonder......I tested way more steel and this one CPM S90V is not best at all
Marvelous(Vaccum Arc Remelting, Electro Slug Remelting and other Russian metallurgical magic)
Well, you sad CPM S90V will be best for this kind of job. I asked if there is any evidence that this is not just theory. You provide you evidence saying that you tested it using four steel on house project. I think this experience you had is limited to this four steels and in my case for wider range of steels CPM S90V was not best so I have evidence that your theory has nothing to do with reality.
I could say the same of Young Earth Creationists and people who think the Earth is the center of the universe and that everything revolves around it:thumbup:.Hello group,
Just for the record I like nozh2002, he challenges people and makes people think!
Thanks,
GP
Well, It's not a theory. It's my experiences cutting carpet which you admit you haven't even done. Where are you going with this? It's not a logical or even rational tack.
i like the fact that you are keeping company names and even the actual amount of cuts "secret" and just categorizing steels that perform similarly. if you released all the info, the pissing contest would overshadow the tests.
The reasons I ask are that different blades may affect comparisons, and different manufacturers run blades at different Rc levels...but you know that all better than I do...![]()
I think if raw CATRA results for CPM S60V and CPM S30V was published at time before "replacement" happen nobody toke that seriously. At least I would not buy it for same price as CPM S60V and would not accept it as replacement.Releasing raw data is the devils playground.![]()
