The stop pin floats on the inkosi.it doesn’t hold the scales together. There is no need to remove it to dissemble the knife or for that matter ever.
That's a good point. I suppose we can just leave that bad boy on there for good. We're all so used to taking apart Sebenzas that it's second nature to want to take the stop pin off. I haven't had a need to take apart my Inkosi yet.
I don't usually carry a slipjoint but this LionSteel slipjoint integral with a pocket clip is pretty cool.
Doc, That stop pin is floating and the scale just lifts off after removing the male pivot screw and the body screw. If you want to remove the stop pin as well that can be done once disassembled.
Edit Thanks @ChazzyP i just saw this.
Correct
Roland,
Correct
It’s an Inkosi not a Sebenza. It’s the floating stop pin not a body screw/spacer.
Correct
It’s not always fun repeating myself. 😂🤣😂🤣 (Jokes)
Chazzy P and Kettleman are correct. The Inkosi stop pin is floating and never needs to come off except for replacing if necessary. 😁
There are three ways you can do it:
1) hold the stop pin with some needle nose pliers and a buffer so you don't scratch it (like copper or brass tape). Better if you heat before if possible.
2) disassemble the knife, so that this will be the last thing holding the two sides together. Then, you can hold the pin in place with pressure between the two scales, so they are not parallel anymore
3) send to the mother ship (that's what I would do)
Roland.
Would it be possible to get an old, gum type rubber band mount it and twist it up tight and hold it that way?
Not familiar with these knives so it is just a guess
