Thanks for asking here. I can't see your images either but from your description I am pretty confident that the stone in question did not get dressed in the center. These diamond stones are pretty hard on the flats they get dressed on so EP does go through quite a few flats a year. The centers wear down faster than the periphery so a dished flat will dress the center of the Matrix stone last, and I think yours didn't get completely dressed. I think all you need to do is dress your stone and it will be fine. Of corse it should have been dressed completely to begin with but these stones do work better after about the 3rd dressing since made so don't be timid about dressing them a few times when new. Again, the ONLY way to dress these stones is with a loose abrasive on a hard flat surface with a little water. Exactly what that loose abrasive is isn't critical but brown aluminum oxide seems to be the best performer, this is what EP sells for these stones. Any other way I have tried to dress the Matrix stones is totally inferior. Oops forgot, a hard stone works very well for maintenance dressing.
I would like to see your photos but until then I have a question. Is the center shinny like in post #159?
Which grit stone is it? After being properly dressed the stone should be an even matt finish.
Finally got a chance to use the stone, and the second good lapping did the trick. Perfectly consistent now. Thanks for being so active on the community.Thanks for letting me know, I have heard of a few stones that didn't get completely dressed now. It's definitly not the diamond settling or being inconsistent, I can assure you of that.
I have dressed Shapton Glass stones with Matrix stones and it worked for both very nicely. I have also dressed some Matrix stones on an EP 1000 with good results so I don't think what you use matters too much, it just needs to be flat and at least as big as the Matrix stone. To dress a Matrix stone this way use a little water to develop a slurry, it shouldn't take more than 10-15 seconds of rubbing the two stones together to clean up the Matrix stone. I think this is a viable method of dressing the 650 and finer Matrix stones, it certainly is a lot less mess than using loose abrasive on a plate.
A while ago I ground some different "granite" tile pieces flat to see if they would work as dressing flats for Matrix stones, just haven't tried them yet.
Hey D Diemaker — I had a thought earlier while using the matrix stones. If this has been covered in the thread already, my apologies.
But have you ever used a nagura on the matrix stones to clear loading during use? I assume it wouldn’t work well on the 80, 250, and maybe the 600. But it may be viable on the 1100 and up. Just wondering if you’ve ever tried it.
I use a cheap King nagura to clear my Venev 150 on the rare occasions when I actually use it. Granted, Venevs use an entirely different resin, but the nagura does a great job of cleaning loading and even exposes a small amount of fresh diamond.
The slice.Huh? signature, I dont get it.
