tongueriver
- Dec 28, 2007
delete
Thanks for that! I'm not familiar with Catalog E though. What year is that from?
Edit: I found it from 1926 with supplements for later years.
Wow. Thanks for that info! So if I understand correctly then, my knife is older than 1926 but based on the tang stamp is no older than 1917? Thanks!Dan, catalog E is about the earliest Schrade Cut Co catalog out there (I do have a "D" which is a bit earlier but pretty much identical). Although the catalog dates to 1926 a majority of the knives in there go back to the very earliest days of Schrade's existence. The pick bone handles on your knife would put it in that category.
Eric
Very cool stuff. Thank you!Dan it's older than that. The straight stamps were done right from the beginning, and I believe that pattern was done almost right from the start. Here's a cut center scale template along with a blade tang gauge I found in the old factory toolroom. That'd put the knife at least at 1912. Incidentally the gauge would have been for the blade on your knife, the cut center was for the four blade version.
Eric
Thanks, I'll have to spend some time investigating that.Your knife is not necessarily older than 1926. It is probably older than the 1930s however. These dates are shifty. Larry Vickery has gone to great trouble to make available views of most of the Schrade paperwork.
This “892” is ruff, but can still be considered as a knife.
