Nice light FO, I have been considering another HDS rotary and it is good to hear that Henry is catching up.
Just an FYI, all other things being equal, we probably can't visually discern any difference in brightness between 200 and 250 lumens.
thanks to Rubi letting me play with his at NYCKS.
What the heck goes on at these knife shows??
N2K, it seems as if you are on the hunt still for the perfect single cell flashlight. Did I read that you think the HDS is as close as you have seen to ideal, but not quite there yet? As for the 50 lumens bump, from what I read our eyes see light in a logarithmic ramp. Therefore, you can easily tell the difference between 1 and 50 lumens but not the difference between 200-250. Seeing that the 1-50 difference is 50x where the 200-250 difference is only 1.25x.
My v11r has a visually linear ramp (from 1-216 lumens on a CR123 or 1-570 Lumens on 16340). The difference between full power and just under full power makes a huge difference on battery usage but I can barely tell the difference.
It's kinda amusing that some of you blame me for HDS buying and now I have to give some blame to Final for pushing me over the edge to try for another rotary. If the 250 lumens is the new output, I'm going for one.
I'm probably going to shake the "cell-phone dice" on this one..... He had a 200 and went to 250 (pronounced "2-fitty") Is 300 that far off? Inquiring minds want to order.
When that happens.... 300 has arrived, cherry-koat solves the grippy issue and 3 weeks in the Gym solves the weight of the light issue - WaLa! Perfection has arrived!!!
Laaaaaaaaaaaaaa (Angels sing in the background and light from the heavens shines with no help from anyones pocket)
Weight issues cannot be resolved with a gym membership. The lights pull down my non-belt lounge/gym pants/shorts when active.
I love my HDS Clicky - it's Hi CRI and only about 120Lumens on max. I have several (2 cell) lights that push upwards of 800 lumens, but find I rarely need over 200. When Hi gets much over that, I typically use Mid.
Anyway, if you really want Small, Light and Bright check out the HF (Holy Flashlight) from TheGuyWithNoName at MatchBox Instruments.
His Nuke is a 10280 battery (about 2/3of on an AAA) and it'll put out 500Lumens on Hi - if only for a few minutes.
I recently won a Ti HF-R. I value runtime and ergos over tininess and extreme brightness, so it's not a light I was ever going to buy for myself. But you can't beat Won - and it really is an amazing keychain light.
