I like simple and useful knives.Padouk, and Olive wood?? Opinels are good, simple but useful knives!!
Take it slow when you file the kick. It's the right solution, but a little tang removal translates into a lot of blade movement!The only other thing I see is that when closed the point of the blade sits just high above the handle, so the point can bite you if you reach for it in the pocket. I have heard that if you file down the kick of the tang a bit, it may sit lower. It has a little extra tang. Any ideas?
Which one???I ordered a Laguiole this morning!
Good question. Ordering a Laguiole direct from the maker proved to be more of an adventure than I hoped for.
As you are aware, I wanted a shadow knife with a carbon steel blade and juniper covers. Simple right? Not so much. The first maker on my list, Renaud Aubry, is no longer with us, RIP. I next looked at PYL, but you know how that turned out. I suppose I could always buy a knife from Bruno Coupat, but I'm not a fan of rebranded knives. I heard from Jerome Latreille last night and he doesn't want to build me a Laguiole with "plein manche en genevrier" because apparently juniper has a tendency to crack at the pins.
Argh...it shouldn't be this hard.
I changed my criteria a little bit. I'm still getting a shadow Laguiole, but it'll be sporting a stainless 12c27 blade and horn covers. Maybe I'll get the knife I want one day, but this will fill my need for a Laguiole.
Might this help?
This one is available from a US vendor for $184.00. Forge de Laguiole is the maker.
Fontenille Pataud will make you a shadow pattern laguiole with juniper and carbon steel. It's a lock back though and I'm guessing that's a deal breaker? I feel your pain and wish you luck!
Might this help?
As far as I understood, Kamagong wants a sleek Lag.Fontenille Pataud will make you a shadow pattern laguiole with juniper and carbon steel. It's a lock back though and I'm guessing that's a deal breaker? I feel your pain and wish you luck!
You don't have to explain that to me! There's been a few knives it's taken years to find the exact requirements for. Renaud Aubrey's passing is certainly a sad thing. More than once I have perused his still open website, wishing....Wow. Beautiful lines on that one.
Thanks for the suggestions fellas. The problem is that I am strangely particular. A Laguiole is not just a Laguiole. When I think of this style of knife, I imagine a sleek and elegant piece of steel. Most of the offerings in the market do not fit the image I have in my mind's eye of what a Laguiole should look like.
The knife I posted above has already been ordered. It may scratch the itch. Then again, it can just as easily wet the appetite and I'll probably be back on the hunt for that shadow juniper.
Is this a traditional or regional French pattern ??
While there are French design elements and it's produced by a French cutler, my spidey sense tells me this may be something Fontenille Pataud just came up with.
Especially since it is said to be produced in tribute to a dog from a specific region of the Alps between Italy and Switzerland.
Regardless, this exact End Grain Burled Beech Le Saint-Bernard lockback is on the way to me ...
Especially since it is said to be named after the Great St Bernard Hospice, a specific location in the Alps between Switzerland and Italy.
It is both regional and traditional, the Alpin, also named Montagnard (mountaineer) or Savoyard, created about the same time as the Opinel. (https://www.lecouteau.info/couteaux-régionaux-traditionnels/l-alpin/ ).I've seen an Au Sabot version of that knife. It wasn't a lockback though.
