The damage seems minimal considering the edge and what was being cut.
secondly ... Jerry does not qualify his warranty by saying "only available to those with a factory profile" ... if you sharpen your knife to an edge you reasonably expect works best for your intended purpose you are still covered ... that I am sure is Busse's view and no doubt they will verify this in due course ... all warranty's on knives are not invalidated by simply your chosen method of sharpening ...
ONLY if their modifications contribute to whatever failure your blade might experience. For example, if someone decides to grind their Battle Mistress primary bevel down to .005" before the edge and then their edge doesn't hold up under heavy abuse then the warranty on that portion of the knife would be void. Other unmodified portions of the knife like the handle, pommel, etc. are still covered.
We can only WARRANT the work that WE do.
Hope that helps, :thumbup:
Jerry![]()
I agree nothing unusual. That is why I suggested trying to put a more durable edge on it now that he knows this limitation.
Peter - is it 900 Celsius or 900 Fahrenheit?
a "normal" guy using his best judgement for an edge and going out to do what the knives were made for ...
Good point ... if the US goes off F then it is F ... I am trying to remember the quench fig's off the top of my head ... but because we use C over here I think that's my mistake ...
On the points made by LVC ... my view is that Jerry needs to cover his back from the "Infi" detractors who occasionally turn up with micro lenses and show damage which is basically making a lot of fuss about nothing ... a "normal" guy using his best judgement for an edge and going out to do what the knives were made for ... I bet he is covered all the time :thumbup:
a normal guy who has machining and metalurgy experience isn't same as a normal guy who has only ever used big box store axes that have 60 degree per side edge angles. The extremes of what people call "normal" makes for a highly variable interpretation of a warranty. I consider this material science, not subjective user experience. That's why I ask about the rc or janka hardness scale of frozen hardwood: the hardness of the material being cut largely determines the edge angle you should be using to protect you knife against damage. INFI is not adamantium, it has limits.
I think 230 is well within the warranty because the competition sar squatches were already thin, and I doubt he brought it down much thinner then was already factory.
Jerry will be along in a minute to say: Send that puppy in!!
More proof that a knife makes a poor axe.
We are supposed to have the same warranty on the thin Busse's as are on the thick ones ... it is unlikely they go off what was the original grind ... if you take it to a logical conclusion ... if the edge was thicker or as thin as on the thinner knives he ought to be covered ...
