For the record.
The blade was modified. By modified I mean the decarb was removed, and the dimples were ground out. They were ground off using a 40 grit fresh belt, and cooled each and every time. The blade never even made it into "warm" territory, nevermind into the arena of destroying a temper. It's almost annoying that every time someone uses anything but a ceramic rod to sharpen or reprofile a Busse combat knife the first thought is someone destroyed the heat treat of the blade. It's not easy to do, especially with a sharp lower grit belt, cooling after each pass. I'm not a sharpening expert, nor am I an expert knife maker. I am however an experienced machinist who is part of a continues improvement team at his job who's goal at the moment is to try eliminating burns on whatever work piece the operator is making. We've been plagued by burns, failing acid etches and MPI testing and destroying tempers. Our focus is designing new coolant distribution systems, to keep the work piece from burning as well as educating operators in new grinding methods to avoid glazing over cutting tools during the run with a too fine of a dress, creating friction and developing burns. Of course here we're in the spectrum of using up to 200 lbs of pressure while grinding, not a light touch on a belt sander.
The edge itself was not thinned a great deal, maybe a little bit, but nothing beyond the spectrum of what a high quality cutting tool should be able to withstand. The only real modification to the cutting edge was a high polish to decrease resistance while push cutting. Once again, heat was not an issue, I know.. it's hard to believe, but i'm not a MoMo grinding and heating the knife with a torch after every pass.
Batoning did NOT present a single problem with the knife, even with lateral twisting bypassing knots, and even with frozen wood. The stress points while twisting during batoning are obviously distributed slightly better when the entire blade is being pushed through, instead of just a thin cutting edge like while chopping.
The knife took absolutely no damage when working with non frozen wood, whacking the ice several times as well. When presented with a larger frozen log, the edge would bite into it quite well, but when making angled cuts into the frozen wood, the thinner cutting edge, as oppossed to the rest of the blade simply could not handle the lateral stress. Straight up and down cuts would not have been a problem if I retested it in that manner. I did not even notice the edge damage until I went to resheath the knife. The edge was so badly dented that the knife would no longer slide into the sheath. I took it out and looked at it and was honestly shocked. So shocked I almost gave it a proper burial in one of our fishing holes, I guess I disappoint easily.
Looking further at the edge, although the blade was dented like a soft machete would end up after eating some hard wood, it was also chipped out very badly, to the point of being serrated. It looked like it bit into the wood, bent and tore out. I was honestly somewhat surprised. Also, despite what many people believe, bending the edge and straightening it again on a steel WILL weaken the edge at the bending point, maybe not enough to cause immediate failure, but this has just been my experience.
I'm not blaming Busse Combat, I think I probably just expected too much out of it. For those of you saying I should have brought an axe, maybe next trip you'll be willing to carry it for me. I buy BC knives so I won't have to carry an axe.
For those of you saying that the stock edge should be sufficient, that's ridiculous. Sure the stock edge geometry on a lot of BC knives are thick to prevent damage, but if I wanted just indestructibility in a cutting tool I would grind a cutting edge on a 2/3 inch piece of bar stock and never worry about a thing. For a knife like the sarsquatch, a thin edge is a MUST. This knife does not have the weight of a bigger blade, so to properly chop into things, the geometry needs to be somewhat acute, sorry but that's just a fact. You're not going to get very far with a light weight knife with the same edge geometry as a MOAB. The reason some of the big choppers chop so well is weight, smaller knives need to depend on other attributes.
As to whether or not the ice had anything to do with it, I can't really speak on. It very well could have as every fish we pulled would stop moving almost instantly when pulled from the water as they would freeze from the wind. The knife was constantly wet and did have ice on it at many times during it's use.
Oh well.
