Grizzly 2x42 Attachments!
This is a presale for the work rests, platens and small wheel attachments I made for the Grizzly 2x42 Grinder.
I can ship a limited number of these within a week and after that it’ll likely be after the 1st of the year before I can fill the rest of the orders. I’ll do this on a first come first serve basis so either post what you’d like below here or send me a direct message/email to get in line!
I won’t require any payment up front. I will send invoices via PayPal when I have each individual order ready.
Price list:
5x12 inch work rest. Will fit with either the standard work rest arm or the drop down work rest arm. - $50
Standard work rest arm. Allows quick tilting up to 15 degrees either forward or backwards. - $14
Drop down work rest arm. Allows for more access to the platen to allow better use of a grinding jig. Only tilts backwards 15 degrees. Does not tilt forward more than a few degrees. - $15
Flat platen. 2x5.25x1/4 inch mild steel. Mounts with 2 flathead screws. - $12
Pair of platen brackets. These allow side to side as well as forward to back adjustment of the platen. They also allow better access to the left side of the platen in comparison to the factory platen. - $18 per pair
Case hardened Radius platens. I don’t have any of these ready as they will have to go off to heat treat. I’ll make whatever size you’d like upon request. These will be 1018 steel case hardened to 60Rc - $50
Small wheel attachment. These are made to run the standard small wheels available from several suppliers. The attachment excepts 7/8 OD bearings spaced 3 1/8 inches apart (Roughly 3.15 true measurement). The attachment includes a tool arm but does NOT include any wheels. It takes up to 2 wheels with the second acting as an idler to redirect the belt. - $70
Shipping/tax will be added on to your total.
Anyone who spends $50 or more I will add a 5% discount.
Either put a reply in here with what you’d like and I will contact you or send me a private message or email.
darren@contenderworks.com
Here’s some pictures of what to expect for finished products. These are bare steel, no paint or plating of any kind. Please keep in mind that these grinders are built cheap. I can’t insure that the attachments will fit them all exactly the same. If anyone runs into trouble with stuff not fitting your grinder please let me know!
Also, if anyone has anymore ideas for attachments you might want built feel free to reach out to me.
Thanks,
-Darren
Do you still have the small wheel attachments available? If so I would like one
My new 2x42 is supposed to arrive 3 days! I’m going with the Contender Mods and I am wondering if the original 8” drive wheel from my G 1015 would work as a contact wheel.
I have only ran into one grinder so far that had trouble fitting an 8 inch contact wheel (with 42 inch belts). All the others seem to have fit ok. So I am not sure if there was something slightly different on that particular grinder. An 8 inch wheel, and even 10 inch wheels, will work with 48 inch belts.
