Are you able to run a 42” belt with the 8” wheel?Not mine. But with custom tool arm setup, sitting a bit proud on the idler wheel.
And 8" contact wheel...
Thanks!You are correct the rear idler wheel is to flatten the belt and give more clearance for grinding around the front wheel. So typically a larger 3/4 or 1 inch wheel works well in the back and a smaller 1/4-3/8 wheel works well in the front. The back wheel isn't necessary unless you need the clearance and the wheels can be flipped around if you need the larger one in front.
Are you still offering these? If not does anyone know where I can get these for this grizzly? Thanks!!This is a presale for the work rests, platens and small wheel attachments I made for the Grizzly 2x42 Grinder.
I can ship a limited number of these within a week and after that it’ll likely be after the 1st of the year before I can fill the rest of the orders. I’ll do this on a first come first serve basis so either post what you’d like below here or send me a direct message/email to get in line!
I won’t require any payment up front. I will send invoices via PayPal when I have each individual order ready.
Price list:
5x12 inch work rest. Will fit with either the standard work rest arm or the drop down work rest arm. - $50
Standard work rest arm. Allows quick tilting up to 15 degrees either forward or backwards. - $14
Drop down work rest arm. Allows for more access to the platen to allow better use of a grinding jig. Only tilts backwards 15 degrees. Does not tilt forward more than a few degrees. - $15
Flat platen. 2x5.25x1/4 inch mild steel. Mounts with 2 flathead screws. - $12
Pair of platen brackets. These allow side to side as well as forward to back adjustment of the platen. They also allow better access to the left side of the platen in comparison to the factory platen. - $18 per pair
Case hardened Radius platens. I don’t have any of these ready as they will have to go off to heat treat. I’ll make whatever size you’d like upon request. These will be 1018 steel case hardened to 60Rc - $50
Small wheel attachment. These are made to run the standard small wheels available from several suppliers. The attachment excepts 7/8 OD bearings spaced 3 1/8 inches apart (Roughly 3.15 true measurement). The attachment includes a tool arm but does NOT include any wheels. It takes up to 2 wheels with the second acting as an idler to redirect the belt. - $70
Shipping/tax will be added on to your total.
Anyone who spends $50 or more I will add a 5% discount.
Either put a reply in here with what you’d like and I will contact you or send me a private message or email.
darren@contenderworks.com
Here’s some pictures of what to expect for finished products. These are bare steel, no paint or plating of any kind. Please keep in mind that these grinders are built cheap. I can’t insure that the attachments will fit them all exactly the same. If anyone runs into trouble with stuff not fitting your grinder please let me know!
Also, if anyone has anymore ideas for attachments you might want built feel free to reach out to me.
Thanks,
-Darren
Yes I am sill offering these. I just sent you an email!Are you still offering these? If not does anyone know where I can get these for this grizzly? Thanks!!
Yes I am! Just send me an email: darren@contenderworks.comAre you still selling these?
Yes, I do believe it is possible, and I am actually working on something to address that issue right now. I don't have it figured out quite yet though. The bigger issue I think is going to be getting the grinders to track reliably in reverse.Who better to ask more than someone who knows this machine specifically.
Do you think it’s possible, I’m not that I’m a pro and understanding these separate units, to add a VFD controller so as I can get reverse as well on the grizzly 2“ x 42“ machine?
Yes, that could be a possible concern. But I appreciate your research on this topic. Thank you so much.Yes, I do believe it is possible, and I am actually working on something to address that issue right now. I don't have it figured out quite yet though. The bigger issue I think is going to be getting the grinders to track reliably
