- Jan 23, 2014
If you don't mind me asking, what is the costs to cut it out? Do you just buy the steel stock separate and then send it to be cut out?
I will have to let you know when I make the final call, but there is often a "minimum" cost associated with the work and its around $500. Which led me to think about buying a larger piece of steel, and then "getting more for my money" but that starts pushing the project into "a lot of money" so i have slow rolled the project just a little bit. I could likely use a local machine shop that i use for work, but wanted to make sure to avoid ANY chance of work/private life bleed over, or concern of either side "getting a deal" because of a professional relationship. being 100% honest I will likely only be making the handles for the knives as I don't have the tools at the moment to do the grinding. If everything works out I will likely do a post detailing the design and work etc highlighting the guys who helped, I just don't want to drag them into it yet in case it all goes horribly wrong
