Okay, the contrarian must check in
About the GIB... yes, it is an inexpensive way to get a REAL grinder. But if you are going to do it right you'll almost certainly need someone to at the very least weld the upright to the base in a perfectly square 90 degrees. Failure to do so will create frustration and tracking problems that you won't know about until tou've loaded your first belt and either watched it fly off the side, or start grinding a groove in the idler adjustment block. Sure, you can do like I did and drill/tap some holes and hope for the best, but a wise man would go the other way, and get professional help with that first step. And an even WISER man would verify the squareness of the weld as soon as it was done (before ANY other work was done).
Also, you need to know what sort of platen you'll want, and that the kit only comes with part of what you need for either/both. I got the kit with both platens, even though you can only use one at a time. Neither plan comes with the angle brackets that hold the plate in place. Neither do they come with the plate that you'll use (either as the back plate or the smooth front plate). So you need to figure that into the cost (and complexity of building the kit). You already know (I hope) that you need to buy all the bolts and nuts and washers separately. The list provided on the polarbearforge site does not include what you'll need to finish the platens or mount the wheels. And yes, you'll need to source the wheels separately, and big contact wheels are expensive.
Also note that the GIB does not come with tooling arm(s), so you need to factor that into the cost. onlinemetals.com has steel and aluminum arms in 1.5" square, and you'll probably be better of getting the precut 24 inch length(s) and cutting off the excess.
Next thing the contrarian advises is not to expect that a new grinder will instantly improve your skills. Quite the contrary. Your experience on a 2 x 42 does not prepare you for using a full-on 2 x 72. It's a different beast altogether, and you need to develop new skills to use it properly. There are a LOT of options for grinding with a 2x72 that just aren't there with the fixed belt sanders. Which to use? When to use them? How to use them? Be prepared to ruin a lot of blades before you're smart enough to do things properly.
I will say this... I have found that some of the grunt work of making knives is going a lot faster. But I have not found that I can skip the grunt work because of the grinder. I've seen videos of people who make a knife entirely using the grinder. I'm not those guys. I still have to put in a lot of hand work (at present, much of it to address the problems I introduced using the grinder). Your experience may be different.
That said, yes, you should definitely get a good grinder and some serious shop lighting. Nothing says "I mean business" more than a bunch of halogens overhead buzzing at you.
One other thing... dust collection. Since installing my grinder I generate a LOT more steel dust. I have to stop every hour or so and sweep it up because I don't have a real dust collection system. You should think about investing in one.
