America has reached 250 years, and I am grateful to be here, in the best country in the world. Thank every one of you who helps make this country a better place, those who have gone before and risked it all, and those who've paid the ultimate price to make the United States what we are today.
I live in the boondocks, there isn't even a post office in the town where I live, I have to drive to the next one.Dan Gray said:why so slow?
Yes it has little flexibilty at full hard, it doesn't work well for bone contacts in high cutting profiles. No ductility so it cracks trivially if the edge is loaded sideways. I have used them on poultry and red meats, but I crack the joints and cut only tissue, you have to go fairly slow unless you have a lot of experience....had a little chipping
Depends on what you want it to do. Mine is excellent on ropes, paper, cardboard, foods, plastics, woods, etc. . If you wanted to cut metals and bones it would do that well too, but you would need a profile which would prevent chipping, or course this would lower the cutting ability and you would be better off with a tougher steel for that type of work.you can't have it work right at full hard..
how slow is your car?Cliff Stamp said:I live in the boondocks, there isn't even a post office in the town where I live, I have to drive to the next one. -Cliff
sound like a chance to brake it each time you use it. why bother?Cliff Stamp said:Yes it has little flexibilty at full hard, it doesn't work well for bone contacts in high cutting profiles. No ductility so it cracks trivially if the edge is loaded sideways. I have used them on poultry and red meats, but I crack the joints and cut only tissue, you have to go fairly slow unless you have a lot of experience. -Cliff
Cliff Stamp said:If you wanted to cut metals and bones it would do that well too, but you would need a profile which would prevent chipping, or course this would lower the cutting ability and you would be better off with a tougher steel for that type of work.
Of course for the edge profile I described no steel will handle that type of work,
-Cliff
Cliff Stamp said:. With the edge this thin you can't subject them to even light lateral strain, you could likely break the edge by trying to force it through the end of a coke bottle unless the load was perfectly perpendicular. -Cliff
sounds like a time bomb waiting to happen to me ,, Cliff.Cliff Stamp said:but you have to use high angles of attack and watch the pressure because the edge is fairly weak at 0.005" and again full hard steels have next to zero ductility. On hard materials like that you have to cut small amounts. The edge retention is very high if you do that because the wear resistance and deformation resistance is high.
-Cliff
shgeo said:Hell I can kill Pepsi bottles by whackin' 'em with a lead-filled snowshoe.
Kim Breed said:Can I use that cinder block in my next spec sheet. I have a new laminate folder from William Henery that has an edge hardness of 65 RC. Should I use a 2 x 4 or a hammer to knock it through.![]()
BRRRRRRRRRRRRRRRRRR and those wells dig hard tooTom Buchanan said:hello dan, i know what you're saying on the winter.i spent 2 yrs up at caribou in the fifties.colder than a welldiggers butt in the klondike.
c.m. arrington said:Would a forged Pepsi bottle be better than a ground one? Would a 550 cord wrapped handle be better than a full tang handle? Hmmmmmm, I wonder......![]()
c.m. arrington said:This thread has gone way OT.
Dan Gray said:but is it still sharp?![]()
The thickness of the edge behind the bevel.howiesatwork said:By the .005"
Because it is the optimal profile for cutting ability and hardness for edge retention if you know how to use it without overstressing the edge.Dan Gray said:sound like a chance to brake it each time you use it. why bother?
Cliff Stamp said:It isn't the geometry and hardness I would use for everything, the scope of work is reduced of course but I carry more than one knife.
-Cliff
Cut plastics, cardboard, woods, plastic, foods, etc., normal everyday materials in the manner described in the above, same stuff I always do. I am interested if the steel can actually function at all at very low angles, ~5 degrees or so. Assuming it can, after doing the above I'll slowly extend the scope of work to evaluate its niche in that profile.Dan Gray said:how would you test this knife?
That was another joke, it is Tom Krein. I just asked him to grind it as thin as he can using the above spec's are rough benchmarks. I would not hold him responsible for the performance, he is grinding to my specifications. The steel may not even hold at that thin a profile, it might just come apart on the wheel. I don't care about that either, the information is worth the knife.it bothers me that you won't say who you got to do it.
been thereCliff Stamp said:This just shows his willingness to experiment which is one of the qualities I look for in makers, probably the primary one, you can't learn if you never try something new, without the possibility of failure there is no chance for innovation.
-Cliff
