- Oct 31, 2009
Sandvik, Mitsubishi, Iscar, Gorilla, all tops in carbide machining /carbide inserts/machining tools, why would their knife steel suck?Yes Sandvik. They area a quality supplier!
My personal experience of over 40 years of using and sharpening knives has been the exact opposite of Mr Gaston444. In my experience 420J2 has been an absolute junk steel. It’s used on “gas station” throw away knives and only keeps any kind of edge that one can manage to get on it for about one cut through any kind reasonably tough material. Bucks 420 combined with their excellent heat treatment makes for a decent edge holding blade. So far Kershaw’s 420 in my experience has held its own against Buck’s 420. Aside from those two manufacturers when I see a knife made of 420J2 or 420 I keep scrolling.S30V, S35VN, CPM 154, CPM 3V, all easier to sharpen for me than most 440.
I know people swear CPM is all premium stuff over 420J... Yet $100 Chinese or Taiwanese specials in 420J will routinely mop the floor with $2000 customs in S30V or D-2. That is just the way it is. Ever heard of the emperor and his clothes?
Gaston
You are ideally wrong on most points.
440C or B, or even A, sharpens poorly, even with diamond hones. It is the nature of these alloys that guided sharpeners are always a plus. Even after 30 years of experience sharpening free hand, I find 440 to be the toughest steel to get a consistent edge with, even with several grits of diamond hones, from Xtra Coarse to Xtra fine.
Mind you, it is easy to get a sharp inconsistent 440 edge, or a sharp 440 edge with a wire edge ready to curl out of alignment on the first 50 chops... But a truly quality edge that is consistent throughout, that will not reflect uneven facets, or especially show any roundedness around the knife belly (the dreaded dull belly syndrome), and will thus touch up easily dozens of times with a single swipe because the apex has no wire edge, and is at the top of a single unobstructed flat surface, that is hard to achieve with 440...
Hardness to sharpen is somewhat related to how long a steel will hold that edge, that may be partly true, but it is not entirely related. I have found, while testing chopping in wood extensively with 10" blades, that for this type of use there is little to no discernible difference between even lowly Chinese 420J and the best 440C, and I even think that for the initial fine edge holding, 420 is somehow ahead, showing less tendency to micro-roll, at least on the first 100 chops.
Despite this, 420J is far easier to field sharpen to an edge equivalent to the ideal description above, about on par with most Carbons(!), and way better than 440. Now is that because the more accurate and consistent edge causes this edge holding superiority? I don't know, but it does makes the "cheaper" steel superior in my view.
It may be cheaper, but 420J is the steel I wish was on all my knives. It does seem to do poorly in extreme cold, not sure why.
Gaston
I don't chop open my mail. I don't chop open packages. I don't chop cardboard boxes up at work. I don't chop open my 41oz bag of Skittles. I don't chop that loose thread off of my worn t-shirt. I don't chop a splinter out of my finger that I got from chopping through a counter that happened to have a pizza on top of it.
You are wrong. So wrong.S30V, S35VN, CPM 154, CPM 3V, all easier to sharpen for me than most 440.
Getting rid of the wire edge isn't even that difficult on those, especially compared to 440. The trouble is the wire edge re-appears on the very first hit in any wood. Rub your nails away from the edge, and you will see, from the grabbed whitish stuff after just a couple of hits, that these are not knife steels. Unfortunately, some cheap Chinese made Kershaws (7Cr13 I believe) do the same slicing cardboard, so you can't even rely on cheap Chinese junk steel just because it's cheap Chinese junk steel... You can't trust anyone these days.
Gaston
Gaston
I don’t who you think you are to accuse me of anything Mr keyboard commando! I don’t have access to any kind of hardness testing machine so I can’t test the hardness of any of my blades. I highly doubt you do either. What I spoke about was my own personal experience with Buck’s and Kershaw’s 420 steel. I’m not a BIG fan of either but I have used both in the field and my experience has been that they both hold a decent edge. Nothing to write home about but decent. So go bash on someone who don’t know any better because you’re wasting your time on me, I do know better! Have a good day sir!Yeah that's some real honest salesmanship if I ever saw it![]()
I am comfortable with Case's use of 420HC as well as the old Schrade USA knives. On recent Bucks, I would just say you get what you paid for. Most regular people like a softer steel because they can sharpen it. The harder stuff is ....well harder for the most part. The old 80's Gerber Gator's weren't bad but were a bit harder to sharpen than some. I one from that period and used it as a hunting knife then. Almost always used folders for hunting knives back then.Does anyone here know...I mean really KNOW...how hard 420HC can be? I read that it tops out at 55 RC, but someone is trying to tell me it goes to 59.
I have two Gerber Gator II knives made from this stuff, and they're very soft. Worthless except as cheap beaters.
I have seen old knives that have been sharpned that much there is nothing much more than a toothpick left, so i would prefer a steel that kept the edge even if it took a while to sharpen.
Dad did that with my first "good" knife as a kid. But I used it a lot. No regrets.That's potentially poor sharpening technique more than steel dulling too quickly. People do odd things to sharpen. I had a knife down to a toothpick in just a couple years, but that was because l sharpened it aggressively on a belt sander.
From what I've seen, 420HC is closer to to 1% than 0.46% carbon.Not exactly Ginsu.420HC is in class with another right under it called 420J2 which is used for liner locks,and handle materials...they're known for their tensile strength.Softness and very fine grain structure allows these steels to sharpen up easily and cut well so they do serve in the outdoor industry.But the caveat is it's a blade crafted from what's used for disposable scalpel and razor blades...it's 0.46% in carbon.Most of what you'll encounter in mass production stainless steels among affordable knives yields between 0.60-0.75% in carbon.
A little over 20 years ago a few other USA knife manufacturers started using 420HC in place of 440A for several reasons...
*Much cheaper than 440A.420HC was still rust resistant so people paying for the upgrade to stainless? that was the selling factor.Didn't matter if it underperformed the previous steel or not,the point was people were paying for stainless and they were getting that.
*It was fine blanking where 440A was not
*The beauty of 420HC was they could throw it in with a batch of 1095 Carbon Tool Steel and give them the same heat treatment mixed together and get them 57-59rc.A minimally alloyed stainless and non-alloyed steel were easy to harden and boosted production.440A required a separate heat treatment because it took finesse to harden as a higher alloyed steel.There is nothing particularly 'glorious' about Buck being able to harden their blades to 58rc(laughing)...that was a standard.
The bottom line is Buck uses a cheap steel.The widening of the bevel and narrowing of the edge angle called Edge 2X (Edge 2000 back then) gave more cutting surface and sharpening ease.A functional gimmick back then because it made people believe back in 1999 that Buck had a better heat treatment...nope...just improved edge results.Easy to achieve through re-profiling a blade.It was a useful gimmick back then because only a few manufacturers like Spyderco,CRKT, and a few others had such a great factory edge.Now it's an outdated gimmick because most knives come with a pretty good bevel and edge.All Buck has now is old marketing to sales pitch their 420HC and promoting it just because it's slapped on it a USA made brand.If it said 'China' on the blade a lot more people would be honest with you about it.
Disposable razors are not 420HC.
440A is used for fine blanking.
I know my Buck 110 can skin and dress 3 deer before it needs stropping.
I know my (USA) Old Timer 7OT (440A blade) can skin and dress 2 1/2 deer before it needs stropping.
FWIW, Schrade (USA) and all their sub-brands (Imperial, Uncle Henry, Old Timer, Ulster, Hammer Brand, etc) never used 420HC, or, so far as I know, 440C. They used 440A for all their stainless steel knives.
Their carbon steel blades were all 1095.
Rather than bad mouth Buck's 420HC, why don't you TRY a knife with it?
It is obvious to those of us who have actually USED a Buck knife, you never have.
As someone stated above, you can get a Buck 110 for $28 at wally's.
Try it before you knock it.
To do otherwise only shows you have no credibility, and do not know what you are talking about.
Bucks 420 is fine, I don't know who pissed in Frotier76 coffee but he has issues. For whatever reason feels the need to prove a worthless point. Buck will continue to build knives in whatever steel they want. They never claimed 420 is a super steel.
5 years with 240 posts and picking on 420HC on post 240?
