I have decided to Test a $350 Plus STRIDER
Here's a couple good reviews that Cobalt recently dug up...
06-14-1999, 06:18 PM
Mike Turber vbmenu_register("postmenu_688576", true);
Registered User
Busse Combat Knives test at the Blade Show!
Jerry and I talked about doing a test at the Blade Show and we did just that. Unfortunately we could not make a big scene about it so we went out back and just whacked away at some 1" hemp rope. The test was a simple rope cutting test. He held the blade against the rope and pushed it through the hemp rope. Jerry wanted to show me that his basic line (Which I just picked up as a distributor) would do everything he claimed.
Up to this point all tests on Busse's knives where done in house without anyone outside of the Busse camp witnessing the results. Well not this time. We did this test right out in the open and many BladeForums members could watch the test. Several people came by and watched at least part of the test which went on for quite a while, nearly 3 hours!
Those who watched at least part of the test were:
Les De Asis, Kit Carson, Rob Simonich, Bob Taylor, Field & Stream magazine and many forum members plus several people I did not know.
The test was simple. We placed a 2X4 on a table and clamped it down. We made guides, to lay the rope down on the 1&1/2" track the rope would lay on, for the cut by simply drilling some screws into the wood. Then Jerry took out a HUGE roll of hemp from his van. Jennifer (Jerry's wife) and I both would count the cuts. We each had a calculator and simply added each cut as it went through.
We used a Basic #9 for the test. We marked the blade with a marker so Jerry would be able to easily see and use the same part of the blade. I was amazed Jerry wanted to do this test even though his hand is still recovering from his accident.
Anyway I will cut to the chase as I am still tired from the show and this very poorly written review is a Testament to that.
Jerry's previous rope cut test with a Basic #9 made it to 1,254 cuts. This is truly amazing but the fact was that he video taped this test and he told me the reason they stopped at that count was because he was running out of video tape. Well for our test he did not need a video tape as I witnessed the entire test from start to finish.
How many cuts did we get?
2,771!
And we only stopped there because we ran out of rope!
After the 2,000th cut I was still able to shave my arm! At the 2,500 mark it lost the ability to shave but still sliced through paper really well. Lori took several pics of me shaving my arm and I will post those soon as well as the pics of the test.
Folks this is the most amazing thing I have ever scene when it comes to knives. During the test I wondered if the knife was actually just getting buffed by the rope. We even had hit the screws on the board at least 6 or so times. I was truly impressed and this has wet my appetite for a more complete test of the Basic line as soon a they ship.
I am tired and must get some sleep so look for more posts later.
Best Regards,
Mike Turber
BladeForums Site Owner and Administrator
Do it! Do it right! Do it right NOW!
Originally Posted by Cliff Stamp View Post
I finally got around to doing this mainly because I was showing the blades to a few friends and the question arose as to how strong they were. I didn't actually know. I knew they were supposed to be fairly flexible but strength was one of two areas that I figured that the Busse Combat blades might not rate too highly in.
When I first starting hearing about them I figured that the steel must be highly wear resistant with good ductility. You can't really argue with that, well you could but you would be insane as demonstrations have been done live. So basically I took those properties as a given.
However there are usually consequences to that. Make a steel very ductile and it tends to be very weak. Make a steel very abrasion resistant and it tends to be very brittle. So at first it seemed to be that the INFI blades could very well be brittle and or weak. This was not very likely however as it didn't seem to be a commonly reported problem - but then again that isn't 100% proof of anything.
After using the Battle Mistress and Basic for a short length of time it was readily obvious that neither of those problems were present. While the steel may in fact be able to bend a great deal it is very resistant to being bent in the first place.
I had my brother who was about 180 lbs do pull ups off of the Basic with just the edge supporting it and the handle didn't even flex excessively. I also dug with it and the edge didn't readily chip out. It dented up and rolled - but cam back strong after some steeling.
Back to the question at hand. I didn't really know how strong the blades were. I had done some light work with them and didn't see any major bending, but never strained them seriously. They are supposed to take a good deal of flex so I figured that this would be a safety net as I knew both could go beyond 45 degrees.
So off we go to have a look at the strength of the blades. I passed both blades around and they get lodged in some stumps and pulled on hard. No problems and a lot of wood is being ripped apart. After things settle down I take the basic and stick it halfway in a piece of spruce about 6-7 " across. I mark out 45 degrees and have a few friends watch the mark. I intended to stop if I passed this and look up the angles before going beyond it.
I start pulling and get about 45 with the handle arcing beyond it. This is about as far as I can go so I bounce on it a few times and give up. I repeat this going the other way and it holds fine. I then try a few times to move the blade out so I can get more leverage. However this just tears the wood apart and the stump splits. Nice sound effect.
I move on to the Battle Mistress, and even though it is much longer, I have no luck getting it to reach 45 degrees when it is lodged at the halfway point. It is simply too strong. Againt I try with the point but it just readily breaks the wood apart.
I have also heavily stressed just the edge but since the blades are not differentially tempered it is not overly weak either. Chop the edge stright into a piece of 4x4 and torque down hard and it splits the wood easily. The points will also take very hard stabs and torques into wood as again they are not soft.
So in conclusion Jerry the knives are pretty strong, of course since you made them you probably already knew that.
-Cliff
Originally Posted by salamander View Post
I Just did a little test of my own. The knife is a Busse basic five. We have all heard of the drop test, where the blade is dropped on the tip from a few feet to see how it holds up. Well I did the following:
I dropped the knife from five feet onto a cement floor. No problem here, then I dropped it from seven feet, again no problem as expected. Then I decided to stop playing around and took it to twenty five feet, dropped it, and guess what, No problem. So I did it again. Nothing wrong except very minimal scratches to the tip which I sharpened out in about twenty strokes on the coarse dmt. Next I decided to chop wrought Iron. It held up as I thought it would by only compressing the steel and rolling it to the side. I must add I only chopped about five times and moved on to the well known flex test. As Cliff stated It fared well, no effect. That was it. I'm done testing Busse knives. Now it's time to collect them one by one. The entire combat line and then the variants. Later, Jeff
BTW: The real test was my own personal useage over the last few months, in which it fared very well. These tests were done for fun, but I thought I'd pass them along. Jeff
In a recent thread on the Camillus forum :
http://www.bladeforums.com/ubb/Forum21/HTML/000257.html
Will Fennel commented about cutting pop cans half filled with water with the Magnum Camp knife. I have wondered from time to time how difficult this is but never actually attempted it. Yesterday I finally got around to doing it. I took out some pop cans and dragged my brother Pat along as he has more reach and speed that I do.
My first cut was very off, much to Pat's amusement. I slammed the blade into the can and actually hit it below the lip and cut upward throwing the can upward in a nice arc and it landed about 15 feet away. Pat's first cut made a complete show of mine. His cut entered the can just above the 1/2 way point and cut on a slight angle into the water. He sheared nicely through the can and the end just tipped over and rolled off the table (it was not level and it was windy out empty cans will not stay upright).
Determined to reproduce this I took more care and made a controlled cut. i got a similar result, clean cut and the can toppled over and rolled off. Pat duplicated his first cut. it then came to me that if I could cut at a higher angle I would force the can in place. I then took a 4x4 and stood the can on it and cut at about a 30 degree of so angle. The can was neatly sheared in half and the bottom piece stayed on the post.
A couple of notes on the condition of the Battle Mistress. It has 4 rust spots along the edge because a couple of weeks ago I wanted to see if it would rust if I put it away wet with no protectant. It did. I then left the rust on to see if it would increase. it did but very slowly. The edge also has a couple of dents about .2 to .1 mm in depth and about 1-2 mm in length as I was chopping up a coat hanger with it. I have some digging to do with it which is why I have not sharpened it yet. Before the cans were cut it was scraping sharp. This means I could shave with it but my skin would be irritated. The edge was not effected by the pop can's.
After the can cutting was finished I tried to cut a paint can in half. I could dent it up readily and sent it flying about 20 feet but not half it. I need to work on my technique.
-Cliff
[This message has been edited by Cliff Stamp (edited 04-10-2000).]
Originally Posted by Burke View Post
This Saturday my aunt called from up the road and said that there was smoke coming from the woods a little less than a mile behind my house and she had called the fire department. Well, having just completed my Federal Firefighter Type 2 training, I figured I'd hike up and have a look-see. I brought along a shovel and my Battle Mistress. Sure enough, a campfire had gotten out of control and was burning close to an acre of dry leaves. I used my shovel to smother the back end of the fire, and my BM to cut up several small logs that were smoldering so I could toss the burning ends into the black (burned out area). Once the fire department got there, I helped hump hose around for a few hours. The BM also saw use prying apart hollow logs to check for embers, and digging out hot spots at the base of trees. The damage I mentioned? The coating is worn smooth in one place, I found a tiny nick in the edge, and the sheath kind of smells like smoke.
Why can`t you make an INFI folder?The only folder I own is a Greco raptor from 3/16" stock of 8670.I paid 55.00 and it`s 10X the knife of the Sebenza,also a framelock,but all steel.
I would only use a comparison using a numerical factor if I were making a quantitative comparision. I think you are making a qualitative comparison. Perhaps your choice of words might lead someone to believe that your observation is the result of an emotional reaction, rather than an informed opinion.
I have a knife that is 6x the knife of the small Sebenza. It is an 18oz khukuri. I don't have anything that is 10x though. Perhaps I will one day get a big fat CAK. I'll let you know if and when that happens.
I think I'm catching on! I like to say things like "You suck" and "I hate you" when I'm envious of someone having/showing off/discussing an item I haven't been able to obtain too.
Do you have anything that is current, as far as accusations of misrepresentation ? I'm waiting for any real evidence that you know "anything sharp" well enough to write about it.
What I meant was that the Greco is the same design(frame lock) as the Seb,but all carbon steel and not Ti which is pretty soft and 1/8" s30V which is brittle.Greco lock is the most secure that I`ve ever seen on any folder.All this for 1/8th of the Sebbi`s price.
I know Infi isn't 440C or 440A because Infi does things that those alloys don't do. I know Infi isn't 1095 because I have never seen Infi rust.
The chemical composition of Infi has been posted on this board. It's not a secret, it's just proprietary.
If I said the sky is green, does the burden of proof lie upon the sky?
If you accuse a woman of Witchcraft does the burden of proof lie uppon the woman?
Pot metal is used to make all kinds of things, does that mean it is makes a better knife than Infi?
Why don't you put on your pajamas with feet, go to sleep and dream about that awesome set of safety scissors you got in your stocking.
I had about 10 Busses and sold them all before the current psychosis,no I can`t afford them now and wouldn`t ever buy them even if the prices go down to their old retail.I pay with US$$ and not INFI checks and expect complete honesty and openness from the makers.I don`t like the idea of proprietory steel,it begs to be paid for in chocolate gold foil-wrapped dollars.
It's pretty obvious you didn't test them! You had 10 Busses, and didn't test a single one, and now you say it's not worth it! What a crock, my friend.
I just bought a nice 4" Scrapyard knife made with INFI for under $150.
Hell Razors were also very reasonably priced. NO ONE has to pay a lot for a Busse knife, NO ONE. Just keep your eyes open, and if in doubt send an email to Idahoskunk of the company store or call the Busse shop themselves. OR POST IN THE WTB FORUM that you want a cheap Busse user. Don't be picky about what is offered, but you'll be able to get one in the approximate size that you want.
Yes, there's a lot of high $$$$ limited runs, and such, especially in the 2ndary market, but YOU DON'T HAVE TO BUY THOSE.
BTW, for those of you who think that Busses are expensive, see if you can find a sword with anywhere near the strength of the AK47 for less than $2000!
I don`t like their designs except for the old SH line,these were good.Also,epoxy coat screams "CHEAP",it`s used to coat office furniture,gym equipment and Busse marketed it like varnish on a million$$ Stradivari violin.If you charge big$$,use DLC for Christsake!They trained their fans to obsess over minute inperfections in the epoxy , someone would weep every day on BF:I got a Badger with a speck of epoxy missing 2/96" of an inch away from the edge,so I`m selling it for 50.00 under retail.....
"It's not a secret, it's just proprietary." We are not a secret society,we are a society with secrets.
Ask a lawyer, there is a big difference between proprietary information (protected by patent or copyright) and a trade secret.
Both can be protected intelectual property.
You probably don't know the difference between slander and libel either.
So epoxy has multiple applications and that makes it cheap. Infi has few applications, so that makes it inferior?
Make a choice.
Oh, for the LOVE OF G-d, now you're just nitpicking. If you have any legimate complaints, post away. Until then, no one cares, and the rest of your so-called arguements have been COMPLETELY blown-away. :yawn:
And as far as "training" goes, what do you think we're a bunch of ignorant dogs? HECK NO, Most of us have bought numerous other knives and have chosen Busses because they are THE CHOSEN ONES! (Okay, I don't really mean that, but they are the best!)
Noone except Busse knows what INFI is for sure.All I want is an independent test(preferably many tests) of extreme abuse of a Busse knife and a similar knives made from KNOWN steels and published results.That`s all.No,one more thing,no powder coat.Please?PS>I didn`t use them because I didn`t want to disturb the perfect epoxy and end up homeless.
Owning an item and selling it later doesn't mean you know every in and out of it. You simply obtained it and got rid of it. I agree with Walking Man, you obviously didn't test them to there full potential.
I find it amazing that you found somebody (or MULTIPLE somebody's) to buy 10 Busse knives? If they are such a gamble, I would think it would be quite hard to sell them. Obviously Busse knives are great performers for the price you pay...as evidence I give to you the entire Busse community here on the forums. How many people is that?
I'd like a response to this as well. It brings up good points of INFI that can be EASILY spotted on the other steels. How would you explain it, if INFI is supposedly any of these steels? Is it magic?
Disclaimer: I've never personally owned a Busse. Why am I making a big deal then? Because eve as a third-party outsider in the matter...I can see a gaping reality when it appears. There is alot that has been posted here showing Busse knives to be VERY durable and worth there retail value, and even more as to the integrity of the INFI steel they use. All I've read or seen to counter this quite obvious evidence...is talk of "rumors" and personal beliefs that don't seem to hold any water.
DUDE, you had 10 Busses, and the opportunity to test them yourself. I would like to see testing as well, but who is going to pay for them? The folks in hell also would enjoy a nice glass of icewater. Jerry has done plenty of testing, but since you don't seem to believe any of his or anyone else's testing results, I guess that you are S.O.L.
Busse offers us our ultimate dream and people(me included in the past) will succumb to the PR ...
You don't buy the steel because it has a cool name or promotion. You look past all of that and ask one specific question : What is the GUARANTEED performance of this knife? Busse didn't get a performance reputation based on a mystery steel, everybody either has some secret name or makes up some special heat treating recipe. Busse however publically demonstrated the performance of his knives at many shows, invited other people to participate in the demonstrations and then guaranteed the performance to the customers.
Here is what I believe about INFI....
There is no need for a faith based perspective, just go look up the composition. It is known and has been for quite some time. Forget about the rumors and ignore anything by anyone who spreads rumors because people who lie don't tend to be singular in communication.
-Cliff
God told me INFI is the best that ever was or will be.
