Cliff Stamp
BANNED
- Oct 5, 1998
I'd choose soft 13C26 (RC60-61) over hard S30V (RC60-61) for non-culinary/non-skinning uses.
Yes, push cutting is for high edge stability, high carbide is for long term wear / coarse / thick edges. Hopefully, sometime soon this point which has been repeated endlessly for about ten years now (and has even been published in recent years) will actually sink into the people who continuously do the opposite. Overseas this is really well known and knives are so designed.
Hmmm ... I wonder if he was talking about the actual edge apex;
The actual apex, less than 0.1 mm wide is about 25+, just a couple of passes on the finishing stone usually, depend on the axeman, but most will do it. The main bevel is actually under ten usually, 6-8 and then transitions to a secondary bevel when the bit dips under under 0.025" thick.
These numbers will be adjusted of course depending on the skill of the axeman, his strength and the type of wood and its conditon. But for example 0.025/15 degrees is a really obtuse bevel that I would use to cut through knots on seasoned spruce with a 3.5 lbs full length felling axe. This should point to the extreme nonsense of 0.030"/20 degrees on a small folder, especially when there are constant rants about abuse with such knives.
And it certainly begs the question why Juranich's own Razor Edge sharpening guides are designed to produce such grossly more obtuse edges.
Mass Market. Many of Spyderco's knives will come in vastly under the current Sharpmaker settings.
If S30V can handle that it should be child's play for 13C26 to have similar or better durability at a more acute profile (it better!), but time and cutting will tell the tale.
Properly hardened it has to, no different than Ti has to be lighter than steel. Material properties are material properties. AUS-8 would also be expected to have better durability as would 420HC, again properly hardened.
-Cliff
