Is that man lifting a dog? Also, I wouldn't mind hanging out with these folks.
Whatever you do with this will be more attention than it's had in quite some time. The blade will be difficult to sharpen first time around because of the rust hardening but other than that it'll chop just fine once there's a new handle on there. What's nice about double bits is a handle is much easier to make from scratch than is a curved axe version.Don't think I've posted in this sub forum before but here it goes. Just picked up this double bit True Temper Kelly Perfect. There's a junk store(complete with the cigar smoking octogenarian owner manning the counter) next to my barber's shop that I usually peruse before cuts. This was to be had for next to nothing so I overlooked the chip, besides that she looks decent, what are your thoughts?
You did very good for $50. That's a plain tooth felling saw. The shallow spine is designed so that you can get a wedge into the cut sooner. It will need to be jointed, set and sharpened. FWIW, I think the best 'first saw' is a 42" to 54" one man saw with an auxiliary handle.
I'd bet the old Plumb was used in the logging industry. That's where you will find such heavy use on one side of an axe. Also it shows the remnants of a half-banana grind - something you're more likely to see on a professional's axe than on some homeowner axe. Also, whoever cared for it kept the face of the bit correct - e.i. the toe and heel length in proportion to the center of the bit. It's not too rounded off. That's another sign that it was owned by somebody who knew axes.
The rust is pretty light on that Plumb and I think it would look great if you just cleaned it up with a wire wheel. A vinegar bath will remove the wonderful patina that lies under the rust. As you begin to sharpen it keep in mind that it will have a very hard oxidation layer on the surface which is difficult to file through. At first it may seem nearly impossible to file. The trick is to work through that layer in one small area and then work your file out from there, lifting the oxidation layer from below. Once the oxidation layer is removed it will file easier.
If I'm not incorrect, plain tooth saws are more for hard woods, but it's all a matter of particulars. Way back, almost all saws were plain tooth, but then rakers were introduced to remove wood faster in softer woods. Then you get champion/tuttle tooth, Great American, Lance and perf lance, etc.
On the whole, you can use any pattern to cut through anything, but what's more efficient and easy is where you get into all the tooth pattern choices.
My experience trying to cut sugar Maple/Rock Maple with a plain tooth was not a positive one. Cutting any kind of softwood, especially green, they worked great though. The plain teeth tear the fibers apart more, so something less dense is easier to cut.
