With soooo many knives and steels available to us nuts, it's pretty easy to satisfy my knifely desires while maintaining my sinophobia (thanks google).
As an English teacher, hats off to you for that one.
Ah, but if you follow the mentality of those choosing to buy from China(mostly as a cost cutting measure), it follows that the cost cutting would extend to the materials and QC as well in a lot of cases.Valid points, although it's worth noting there is absolutely nothing wrong with knives from China. They aren't inherently bad because they come from there. Many reputable U.S. manufacturers have entire lines that are produced there, with high standards... so I'll assume you meant the knives that are produced there at substandard levels in substandard conditions.
Common myth. Given proper sharpening skills and equipment(very cheap equipment at that), I bet you'd spend more time on upkeep of those older/simpler steels than I would with some of the supersteels given equal use amount and patterns. On top of that, if the use is intensive enough, the blade will be gone on "easy to sharpen" older knife, while new one will still have quite a bit.
Given same amount of material cut supersteel category needs less time to review the edge, simply because less wear and tear occurs.
Speaking as someone typing on his Made in China Apple iMac, I fully understand that not everything that comes out of China is substandard crap. But I think it's safe to say that most substandard crap comes out of China, if you get the difference between the two.
As an English teacher, hats off to you for that one.![]()
Quote Originally Posted by Gator97 Common myth. Given proper sharpening skills and equipment(very cheap equipment at that) said:Do you know for certain that's a common myth? Have you done some testing in this area or are there tests to which you can direct us? I ask in all seriousness because if it is truly a myth it's one I have believed, and if you have done some tests and studies that can disprove it, I'd change that outlook (although I'd still always love Opinels just the same).
Part of the reason I want a good but inexpensive steel is in case I lose the darn knife.
I am a ham radio guy. Years ago I bought a $400 2 meter (belt carry) radio that did everything but light your cigar. I didn't like having that much money hanging from my belt and being leaned on etc. I bought a $100 radio I could kick around a little more. The $400 radio was clearly "better", just not for me.
Ya, it's not that I lose stuff. I don't really. It's that I don't want to *worry* about losing it.
You new here? ��
Aha. An epiphany.
What is one going to be doing with a 3" to 4" FOLDER that they would need the same type of steel that would be used in a 10" Chopper...?
People aren't going to be chopping down 10" thick trees with their 3" to 4" folders.....
That aside I don't see the difference in maintenance other than the higher alloy steels need to be sharpened or touched up less....
As far as time goes goes for the said touch ups etc is basically the same.... Usually under a minute....
Not really.
That would apply to old and new steels alike.
Keep in mind Sandvik and Crucible are competitors.Due to their high fraction of hard and brittle carbides, these grades are difficult to sharpen and have low toughness. Especially if used on keen edge geometries, these grades have a tendency to chip in the edge, which is known as micro-chipping.
Because so many people have repeated this, it seems to have attained myth status. Look at the 2 CPM 110v threads on the Spyderco Manix 2. I give specific examples of how long (or not) it takes to sharpen these steels and the equipment that I use. Plain DMT diafolds.Do you know for certain that's a common myth? Have you done some testing in this area or are there tests to which you can direct us? I ask in all seriousness because if it is truly a myth it's one I have believed, and if you have done some tests and studies that can disprove it, I'd change that outlook (although I'd still always love Opinels just the same).
The easiest knife that I own to sharpen is a Phil Wilson in CPM 10V at 64.5 HRC. I can have it so dull that you can drag it across the veins in your wrist with no fear of injury, then bring it back to max sharpness in under 3 minutes, without rushing.
The hardest knife that I own to sharpen is a soft 1095 that has a floppy burr that flips over every time you try to get rid of it. Then you have to rip the burr off and start over again. I have quit using it, but keep it simply to remind myself how frustrating even "simple" steels can be.
IMO, what makes a knife hard to sharpen is the thickness of the edge, not the type of steel.
The people saying geometry cuts are correct. The thinner, the better. You can get a hard high alloy steel very, very thin for max cutting ability, while a softer low alloy still is not strong enough to support that thin edge. That's where the advantage lies. That thin edge also sharpens in a *fraction* of the time that a thick edge does.
Yes, that's pretty much my whole point though. If the knife is optimized the way it should be for cutting, the steel makes no difference in sharpening.I have read Phil Watson knives have edge geometry which puts them practically in their own class and that they are unusually easy to sharpen pretty much regardless of the steel. Wouldn't that greatly impact how easy a knife is to sharpen and kind of make comparing the two steels in difficulty in sharpening not the best comparison?
That's true and your point of view is certainly valid as well. Have you tried sharpening a Dozier though? You might not find D2 very difficult, as he highly optimizes his blades as well.Your information on sharpening the 110V Manix is great. But I personally still find S110V to be difficult to sharpen. In terms of the same knives in the same steels, I find the D2 and the M390 to be more difficult to sharpen than the 154CM on my Benchmade 707 and 705 models. I am not saying that makes a certain steel bad, and as you noted it does have to do with the sharpener, but it certainly impacts my personal take on this manner which is one that is difficult to quantify scientifically.
Thanks for your info, I appreciate it. I just have to call out these statements that this or that is not true but then the poster goes on to base why it is or isn't true on (what seems to be) pure conjecture. Sharing your sharpening experiences helps.
Truthfully, I own a lot of different steels and I wouldn't classify any as difficult for me to sharpen. I also use DMT diamond stones (although bench mounted ones, I only use diafolds if I'm out and about and need to sharpen on the move). Granted, I sharpen all the knives that I EDC, pretty regularly, and I usually don't let them get very dull. If I used one throughout the day, it gets touched up on the stones in the evening. Even a steel with reputed great edge-holding capabilities would get a touch up at the end of a long use session because that's just the kind of sharpener I am, I guess. If I can help it, which I usually can, I don't let them get too dull.
I totally agree about edge thickness, although I don't own many knives with massively thick edges, so that also cuts down on difficulty in sharpening.
I doubt you really learned anything.....
Likely 98% of the meat we all eat is processed with commercial grade knives before the customers ever see it....
Yes, that also includes what we all eat in restaurants... As the restaurants are customers too....
That's chicken, fish, pork, beef and lamb...
That's not being cheap, it's what they all use as it's the industry standard..... And they get bulk discounts.....
Most employers aren't going to put $100+ knives in peoples hands for various reasons....... None of them have to do with performance...
At what the commercial grade knives cost they are basically disposable, and not expensive to replace and they meet all of the heath code standards.
