Perhaps YOU can come up with the perfect lock design.
Get your name right up there with Michael Walker. Or maybe even compete with the Reeve's Integral Lock.![]()
it aint the axis lock with omega spring.
This test is a fail. I was hoping that this would be moved to W&C so I could say something snarky with impunity. Lol.
All my slip joint knives fail the spine whack "test" every time.....pieces of junk...all of 'em.
Okay... now everybody that has these terrible knives that fail the spine whack test, send them to me and I will take them with me to the river with my whacked spine![]()
Since when is whacking the spine of the blade to see if the lock will fail "Normal" use?
It's truly a pointless test and probably only weakens a lock that was otherwise plenty strong for it's intended purpose.
I hate to bring it up to someone that claims to use her(?) knives hard: Nobody whacks the "spine" of a knife in such test....Chances are if you are using the knife how it's intended to be used...
....whacking the spine of the blade ....
It's truly a pointless test and probably only weakens a lock ....I've used knives hard ....The point is, use your knife as a knife, you'll be fine. Chances of the spine hitting something and the lock failing are slim to none....
....Your folder is meant to assist you in tasks you need done that aren't beyond what it's intended purposes are.
Oh no you didn't :foot:I hate to bring it up to someone that claims to use her(?) knives hard: Nobody whacks the "spine" of a knife in such test.
...Here is another expert in chances and probabilities that can determine exactly how should one use a knife...
It's a harmless "test" for a knife, the problem is that top dollar knives sometimes are failing it and cheap knives often pass it.
A liner locking knife if MADE CORRECTLY will fail open so it does not close. If it closes for what ever reason other than folding blade in to the frame and putting it back in your pocket/pouch it is made INCORRECTLY! How do you folks not get that? keepem sharp
PS I feel much better now, thanks
