Yep, and it's not just for hunting. All I really need for my day-to-day is a good Swiss army knife, and for the odd times I need to clean a squirrel, I can't do much better than a Buck 102 "Woodsman".
I'm surprised at so many references to folders for hunting. Even for something as small as a squirrel, I don't like the extra work of either taking the care not to get stuff in the mechanics or cleaning out the mechanics. Why not a small fixed blade, purpose-built for hunting?
On a side note, what is involved in field dressing an elk? Seems like they're too big to drag out of the woods whole, and you mentioned using a saw on the pelvis. Are they quartered? Taken out on an ATV trailer?
I'm there too and I agree with you. The $200 knife would be a better choice for a guide along with a backup of some kind in case he looses one.If you think that you need a $200 knife to process an elk, yes, you're overthinking it. That said, if you think you can't buy a knife that will process a whole lot more elk with a whole lot less sharpening and just be overall better suited for the job than the knife your guide used, well, you're just plain wrong.
I have enough knives that I could go through life without ever buying another one. I buy knives because I enjoy them, not because I need better performance, though getting a knife that you find performs better than your others is always great.
One year (deer season) I carried a Kershaw boot knife as my hunting knife. I still chuckle about my choice then. (Don't worry. I came to my senses.) Prior to that I used a Schrade 250T (111 size) for deer hunting needs. I always used a slip joint (Case) prior to that. Worked just fine as far as I was concerned. Been known to carry a Gerber Gator as well. Once I had more choices beyond a slip joint, I jumped around with my choices for the day. They had to be sharp however.Back when I hunted and before I started collecting knives, I dressed deer with a Buck 110 and Old Timer fixed blade. Mainly the Old Timer with a blade that was about 3 1/2 to 4 inches? No clue on the steel. Probably dressed or helped dress a couple dozen deer. Never any issue except the 110 was slick. The Old Timer was definitely easier to grip.
That being said, if I get back into hunting, I'd probably use Large CRK 21 or my Mayo TNT. Because I could!
That would be a good modestly priced choice. I have a couple Doziers that would work perfectly. Sadly, I have not been hunting for the last 5 years. It got to be just too much of a pain in the butt. But if I went back, it would be big bore handgun only hunts for me and I have more than enough really good choices for knives including the Doziers.If I was a guide I would have a Dozier fix blade in D2 steel. I like field dressing 4-5 deer and not having to sharpen the blade.
I agree completely with using a decent & dependable fixed blade for this type of task,I myself prefer a fixed blade for this work and anything between 3 - 6" will do with 4" - ish being the sweet spot for most large game.
I'd say this is fairly typical as they attached zero value to your gift. If you don't bleed to buy a knife, you often do not appreciate it and apt to use it for a "screw driver". For gawd's sake, that is what a SAK is for..... I once gifted a smaller traditional Ram's horn handled folder to a friend of mine, (not expensive) and when I had asked about it later, he says 'I used the blade as a screwdriver and f'd it up'...
so much for sentiment of the gift, & appreciation of the piece.
Agreed!I'd say this is fairly typical as they attached zero value to your gift. If you don't bleed to buy a knife, you often do not appreciate it and apt to use it for a "screw driver". For gawd's sake, that is what a SAK is for.
WOW!!I’ve spent a lifetime cutting up and packing critters out of difficult places
We don't need anything more than this. And it'll never get lock stick!
Have you spine walked it yet???![]()
