Not today habit, probably at least a month or so before we process out the remaining 440A on hand.
Not to ask too many questions in a day but exactly what models are being updated to 13C26 that didn't already have it.
I need a little help from my fellow Kershaw admirer's.Are the kershaw 1725 Junkyard Dog 2's any good? Does anyone own one? Any information would be helpfull. Thanks in advance,Robert.
Max, let's see, it's late, but from what I can recall right now, the 440A models that will be changed to 13C26;
Blackout's, Whirlwind's, Leek's, Baby Boa, Centofonte/Onion's, Blur's.
habit, the Leek's haven't been changed over yet, still a month or so away.
BlackOpsSec, welcome to the forums, to answer your question, the only difference between the two knives would be the finish. The CGTST would have a satin finish, the G10ST a stonewash. As far as the qty produced, both were short runs. There were 128 pieces of the CGTST produced, and 259 pieces of the G10ST.
Mike, well it's a little cloudy of when all the HT changes happened, so I couldn't say for certain. If you feel the HT is off on your dad's Cyclone, send it on back and I'll take care of it.When did the Cyclones (My Dad's is Sep 06) switch to the harder heat treated 13C26?
BlackOps, very cool post, appreciate the support for sure. :thumbup:
Auto's.....hmmmm.......bali-songs.......hmmmmm
Thanks, Thomas, I will send it in to you. Should I send it in attention you or e-mail you at all? It has some pretty bad burring issues that won't seem to sharpen out, which is not the norm from all of the reports I've heard from STR, Thom Brogan, and others (in fact, from what I've heard the burring is usually VERY minimal, which is one of the reasons I am drawn to this steel and recommended it to my Dad). I tried sharpening it to 18 degrees to get to good steel in case it was overheated on the factory sharpening and it still burrs with a 22 degree microbevel. I appreciate your help on this and will send it off ASAP, and look forward to trying some of the good, crisp 13C26 that I've been hearing people rave about. Thanks again for the help.
Mike
Mike, mine (mini) is dated jun 06 and seems to sharpen up just fine. The burr is very minimal and this thing gets sharp! I am loving this steel! This is a sweet knife Thomas and I'm really enjoying it!:thumbup:
As I do believe a dud will get out now and then, lets not misjudge and blame batch heat treatment. With the high tech ovens and low tolerances, and control of heat treatment in factories I think the dud ratio is low, and probably the best heat treatment available any where.
Back on topic another vote for a 3 inch Baly.
Hi denny, welcome to the forums.
Sorry to hear your Groove got to you with some corrosion on the blade. Certainly you can send it back for warranty if needed. There are some various metal cleaners that should clean it up quickly, but do whatever you are most comfortable with. We can turn a new Groove around quickly for you.
We have had some minor corrosion issues with 13C26, but most are very surface oriented, and can be taken care of no problem.
4 inch market would be better.
People just starting out want quality balisongs to learn on, not CCC's, and they want them regular size. Benchmade is the only company they would have to compete against, as Spyderco will probably be stuck with manufacturing problems for awhile. Apparently the Smallfly wont be effected though, so a 3 inch from Kershaw would have to go against the Smallfly and the Morpho, so full-size is the way to go.
