Monofletch
- Jan 14, 2010
Everyone knows scissors are for running!
Everyone knows scissors are for running!![]()
There are other reasons (besides SD) for carrying a knife while running solo in wilderness areas. The most obvious use would be to help cut a walking stick or splint if you roll your ankle on a root/rock. Also, there have been enough instances that I've read about ("real" incidents, with associated news articles/etc) where people have used a smallish EDC knife to kill attacking wildlife, that I'm convinced its a better option than nothing if the need arises. The most recent one was the thread here where the guy stabbed a rabid coyote that was attacking his legs, but also other animals like mountain lion/etc.
And, as many people have mentioned, bear spray or a firearm may not be legal everywhere, so I think the idea of a "trail running" knife isn't totally outlandish.
After my one experience running with a knife, all I know is that I would want something that doesn't bounce or move around a lot (no neck knives, or boot knives in my shoes sorry), doesn't rust easily, and wouldn't make me cry if I lost it. I found that personally that carrying IWB just off of the centerline worked best for me and that one 5 mile run I did with it. YMMV.
I trail run with my Spyderco Pacific Salt SE...
it is slender, lightweight, & rustproof...in other words, perfect for exercise...
I completely forgot that I bought a buck ops boot knife to carry for running when I was in a less than ideal area. The sheath had a ton of attachments and I attached it to my arm (forearm was great for access but not too discrete with short sleeves. Then I stopped running and starting riding bikes more so I can outrun most critters or use the bike as a weapon/barrier. The knife just sits these days though I did carry it for work for a while when we had police in on a regular basis because some workers are...
Did that one come in 154cm?
It is 154cm. It's an interesting blade design. IMO. very stabby, thick spine if you wanted to pry but a hollow grind so still pretty slicey. Handle is a 3-finger so I ground in a front choil with a dremel.
I remember a boot knife being available at the same time as the tops/buck csar-t and the responder, all in 154cm. I bought the csar-t, the thickest-spined folder I ever saw, but I think I regret not buying the boot knife as well. And bos knows how to treat steel, so I know it won’t break normally.
I never carried a knife when I used to run and think it would be difficult to carry any knife comfortably unless you dressed specifically to carry a knife ... meaning something with snug pockets that could hold a clip ... because loose flapping pockets on shorts you could easily lose a knife clipped in your pocket in running shorts ...
a waist pack which some runners use ... especially trail runners I've seen ... then you could carry most anything that fit in your pack ...
a neck knife would bounce and drive me crazy running ... the only option I would have for quick access while running would be a small knife in a kydex ... not leather for safety reasons with possible falls ... sheath on the belt of a waist pack or an elastic belt ... like an Izula II for example ... or a knife in that type of group.
