Cliff Stamp
BANNED
- Oct 5, 1998
Not for what I want it to do. I have 01, 1095 and M2 blades all at max hardness, with Alvin's patented cold treatment. Phil Wilson has been using CPM stainless at high hardness levels for years. He runs the nonstainless ones even harder.Kevin Wilkins said:Sporting knives of M2 work better drawn back to 63-64 and certainly if the blade is more than about 40mm.
S90V performs best at 58-59, 63+ is way too hard for that steel.
Yeah but it's a dry cold. There are lots of advantages, you don't have to water your lawn for example, and when you take kids swiming, they never fight to stay for just 15 more minutes.Glenn Jones said:Do people actually live in places where it drops to -30 or -40 degrees F?
There is no issue of belief. One manufacturer has clearly stated one action voids his warrenty and is damaging to his knives (quoting another poster check the above) and another has stated his knives are designed to handle it. There isn't much room for debate there.Richard Sommer said:You believe that because CRKs warranty doesnt cover flicking, it makes the product inferior.
As noted in the above, this isn't the only point in which the Senebza is inferior to other knives I have used, it isn't even the most important one.
That type of lock in general has problems with torques and edge shear problems, plus jamming, and white knuckle issues. Then you have Sebenza specific problems like softer steel, and apparently now more obtuse edges (see recently thread in the main forum).
Then there are issues with ergonomics, then price considerations when you look at upper level production with matching and exceeding lock strength and stability, and materials.
Lots of them are, I can think of several knife companies right here on Bladeforums that do that exactly. I can also think of many custom knifemakers who do exactly the same. It is mainly, about hype vs performance. The above quotes about rope cutting come directly from two makers.Warrenties arent written the way they are because Company X tested the product in these circumstances and therefore we know it will hold up to this so then we will write the warranty to reflect that.
Yes, chopping is *many* times worse, the impact energy is much greater, and it will still end up being focused on the same points. I have seen lots of flickable folders, only one yet which is capable of extended chopping without lock loosening.As to the stresses induced by flicking versus impact on the edge, such as chopping, they are not the same.
As well in general flicking pales in comparison to simply exerting a lot of force on the blade. Awhile ago I bought 3 small voyagers. I took one part in the lock by just prying not sideways to snap the blade, but up/down to look at the lock. The lock bar broke off with relative ease. Flicking did nothing to it in comparison. I broke the lock in a Buck/Strider rocking it through a piece of wood in a similar manner - mainly due to an inherent weakness to liner/integrals, vs lockbacks and others.
I gave another Voyager to my brother who works in construction. He mainly used it for heavy cutting as he carried an Olfa for all lighter tasks. The serrations all broke off quickly cutting used material and cabling and again the lock went very loose and then failed just with heavy cutting, by this I mean puting max wrist strength into the blade to make deep cuts in wood, often rocking the blade to force it through, some times vertically which allowed near body weight into the blade.
Now they are just plastic folders and for their price I think they are decent though I would prefer the Spyderco versions mainly for the serration pattern. Its just a point about the possible stresses in heavy use compared to the inconsequential flicking impacts. Note here the method of failure isn't the same as in flicking when tends to flatten contact areas, the above tends to cause gross loosening/lateral shears or simply direct fracture. It gets even worse if you start batoning the folders, subjecting them to heavy Harvey class spine whacks - which again note a lot of knives can pass readily.
Would depend on the lube, I don't put any on any of the folders I use and the knife isn't as cold as the enviroment, it is typically on you somewhere. Using them in freezing rain can be a problem as they can freeze open, but using any tools in such conditions is problematic. But the biggest problem for me is I wear glasses and thus I go blind in such conditions rapidly as the lens sleet over and without my glasses I am really near sighted, my far point is like 10 cm so I can't even see the ground to shovel clearly.DCK said:Doesn't the lube on the knife make the action too stiff to flick it open anyway?
Nice resistance to cold by the way, i thought I was fairly decent in that regard, but I need more than a simple pair of cotton gloves when it starts heading towards -30 and I avoid any barehanded work strongly. I move away from gloves entirely at that point and use heavier mits. At this point in Labrador which is close by, schools will start to close with no snow, just due to temperature alone. As well you now have to start leaving your cars plugged in to heaters, more of a problem for Alberta than here.
Maybe a few. I carried one, not mine, for a couple of weeks. I would not flick it significantly as it would void the warrenty, which is a bit of a concern on a knife of that cost especially when it isn't yours. If I was planning on flicking it I obviously would not buy a knife which wasn't built to take it. Which is one of, but hardly the only reason I would not choose a Sebenza as noted in the above....how many times have you flicked open a Sebenza
Not often, I usually carry fixed blades except at work. I do flicking in extreme temps and manipulation mainly for evalution, just like I try with mitts, thick gloves, etc. . Personally its not something that I am interested in its mainly to answer questions I get asked. Folders for me are more for recreation, serious work I do with fixed blades, though the Spyderco Chinook has been changing that as of late. I also also maybe thinking about ER for a baton level folder.or any other superior knife at the temperatures that you mentioned.
Why would I spend time trying to investigate a product when there are superior ones on the market, that seems an odd path to take if you are looking for maximum performance. I look at people making claims of higher performance, not less.Precisely what testing have you done that backs up your blanket statements about CRK knives being inferior.
As for scope of work, as noted in the above flicking is well down the list of stresses when I consider hard work folders and thus when that is called abusive, a lot of other stuff gets automatically junked as well.
As for comparing knives for different tasks, yes that is done often and necessary because of the *huge* overlap. You don't but a knife to do just one thing (rarely), and thus what it can do well, and then ok and then not at all is useful information.
For example the Sebenza is inferior to the Opinel in regards to price, cutting ability, ergonomics, lock security, ease of sharpening and availability. It is superior in carryability, likely edge retention, corrosion resistance, ease of opening, lock strength and initial edge sharpness and formation.
These are of course two knives built for fairly different tasks, however compating and contrasting the two is a valuable exercise. Just like comparing any two tools or whatever, evaluate to judge scope of work and performance and then pick which one has the performance in the fields which are critical to the user.
It is no different than when buying snow shovels. They all move snow in lots of different ways and are inferior and superior to each other at various aspects, some can move more snow, some move less snow but easier due to handle design, some push it well but shovel poorly, some can handle gravel well but are heavy, some are very light but can break easy, etc. .
I personally mainly use an ergonomic plastic one with a wide scoop but have a metal bladed smaller one, plus an ice breaker and a very large scoop. The metal one is the one I would pick if I could have just one as it has the widest scope of work, though it does it all fairly poorly compared to the others, the others simple can't function at all in some areas
Thus while all being optimal at their own narrow niches, overall they are inferior to others for the same general type of work (shoveling snow). Every tool of course is the optimal design for something, so its meaningless to say something is superior or inferior as a blanket statement - these labels are only meaningful in contrast and when you define the judging criteria. All products are vastly inferior to scads of others at lots of things, even in very narrow scopes of work.
When you move to something broad like "cutting" its even more so. The Sebenza is huge inferior to an Opinel for cutting cardboard and woods, foods, etc., its massively inferior to an Olfa knife for paper, threads, even worse on thick insulation - fibreglass and foam the difference is many times over here, and the comparison gets even worst in its favor compare to the Olfa knives for really tough material and hard cutting/scraping which heavily damages edges.
Does it do some things well, sure. If these are the things that are of most importance to you then its the right choice, Reeve sells a lot of them so it is obviously true for a lot of people as many are repeat customers.
-Cliff
