A most appropriate analogy.Megalobyte said:I am like a moth, which can't seem to avoid the flame...![]()
Steelhed said:I could see a new Kliff Stump story coming out of this - something like Kliffy meets the warranty man wherein our intrepid hero compares how Knife Maker A's warranty produces cleaner paper cuts than Knife Maker B's warranty. Afterall, if the warranty is more important than the knife, then why do we not test warranties instead of knives? In fact, Kliff says he's gonna stop carrying knives altogether and start carrying the warranty. He can fold it just like a folding knife, and whip it out of his pocket when he needs to cut something like an apple, or in Kliffy's case, a crow bar. All he'd need to do is wave that superior warranty over the apple and it would fall into bite size pieces out sheer respect for such great coverage. Or he could immobolize a mugger by simply reading from the paragraph that says spine whacking is not considered abuse. I'm sure the mugger would be so impressed he'd pass out from fright.![]()
Megalobyte said:it's a lockback, with a strong backspring, so, ummm, it cannot be flicked open!
Or any of the *many* folding knives that can withstand it.DCK said:... maybe they ought to get themselves a fixed blade.
No they need to be judged against the competition just like any other product. When you buy something, from a toaster to a new car, do you actually just go by what the dealer says about the product, or look at what is offered from other toasters and cars and compare abilities / product support etc. .Knives as well as anything else should be judged what they are designed to do...
If said knives are promoted for similar tasks, or the tasks for the Warenski superset the CRKT then yes. If the Warenski is only capable of a subset of tasks then you would expect both to have radically different abuse determinations.DaveH said:So if I understand Cliff's argument, a $2000 Warenski , which costs 50 times more then a $40 CRKT, should have no trouble standing up to some spine whacks and flicking and what not? That's a perfectly valid thing to do then?
They have inferior warrenty coverage in that regard, its one of the high point of his knives along with consistency of product, initial edge performance, etc. .Megalobyte said:Cliff, what about the fact that 99% of all production companies, with CRK being that lone 1%, consider disassembling the knife for maintainance, voiding the warrantee?
It only takes one maker to say otherwise and thus redefine the standard for abuse, again benchmarks are not defined by individuals but groups.Chris Reeve believes long term, hard flicking is bad for knives, I agree, a lot of people do.
No it is minimal, as noted the stress is really light. For folders it depends on the type, I think I'll pick up a multi-blade this year, I am thinking M2 at 66 HRC, maybe S90v at 63+. Hard use for it will be chiseling plastic, or carving hard woods - carefully. Now if you take something which is promoted with lock strengths in the 1000 in.lbs range, very thick 3/16" blades, lots of steel in the handle - unless it has a very wide scope of work all of that is wasted potential, you are better off with the slipjoint. The reason that you put all that metal in the knife is to allow it to handle harder work.... unless your ultimate criteria for hard use, is flicking, which is pretty silly if you ask me.
No problem, just let me know what you were interested in. Its kind of a funny knife in that the initial sharpness, cutting ability, ergonomics etc. are higher than many other knives I have used. The liner lock has a common problem with all such knives in that its a white knuckle problem (dremel would fix that). I suspect long term that the lock will move across the bar quickly and then get sloppy, but I'll see. It also doesn't have a ball detent so there are concerns about accidently opening.I'd love to see you put your wonderful $5 knife through some really tough tests, tests that actually do determine if a knife is robust and capable of long term hard use
No, its a minimum. However the negative is true. Just like for example if I said you have to be at least 18 to go on this ride. If you are under 18 you don't go, however if you are over 18 it doesn't mean you always go as they can be other clauses (you need money, can't be impaired etc.).The fact that any company or maker says his knife can be flicked or is prepared to fix any damage that results, does not automatically make that a hard use knife, now does it.
It means they are inferior in that respect, as per the defination of the word. Overall superiority would need to look at all criteria and then assign some sort of value and then sum, lots of room for subjective assessement there obviously....it does not mean his knives are inferior to crap knives with unlimited warrantees, to say so is a little silly.
And when it is clear than any such testing voids the warrenty, do you really expect anyone to take such performance claims seriously. Assuming you buy for performance, the only meaningfull claims are those supported - anything else is simply hype. If you are selling a product on the ability to do something then it should be able to do it. That's not really much of a leap of logic there.Steelhed said:Knife performance is objective provided the performance criteria is defined. This can then be tested.
Sure it does, in that regard again by defination of the word. Now of course you can make a superior product and put an inferior warrenty on it and the product could still have superior abilities in many regards. However it it pretty poor logic to expect a customer to belive your claims when you won't support them, or for one user to belive another when the maker won't support the first guyI will reiterate what I said before - a limited warranty does not make a product inferior to another with an unlimited warranty.
Some of the most liberal warrenties in the knife industry are on expensive knives. I have dealt with many makers, custom and production which have 100% faith warrenties and which have existed for a *long* time. Yes cost is an issue, so is promotion. Warrenty claims are usually do to ignorance of the user or overhype of the maker. Both can be solved by the maker being clear what the knife can do and should not do.Finally, a knife that costs many times more than a POS would tend to have a more carefully worded warranty.
When the temperature drops to about -30 you can't have unexposed skin for very long, frost bite can set in immediately at -40 and below its almost instant. You have to wear very thick mitts (no gloves) which make manipulating blades open via studs next to impossible. Spyderco's large blade holes are functional for longer than most, but even they stop being practical at some point.
and you replied with this...Knives as well as anything else should be judged what they are designed to do...
AMEN SteelhedThe best warranty in the world won't make a poor knife any better, and a bad warranty will not detract one bit from the performance of a good one. You can buy knives because of the warranty or because of the quality. When the warranty and the knife are both good, then heaven and earth abide.
Cliff Stamp said:Or any of the *many* folding knives that can withstand it.
-Cliff
