Kevin Wilkins said:Some simple "reverse engineering" should suffice there! There aren't any big secrets in heat treating and there aren't that many stainless steels to choose from either. The solution to the problem of a round stop pin contacting against a flat blade rear is tough. You need to increase the contact point from a tiny tangent on the stop pin. Some use a rounded contact surface on the blade, but I don't know how much this really helps.
What do you think of Darrell Ralph's Maxx design, where the thumbstuds act as stop pins? This would have two pins impacting twice or more the surface than a blade, since they hit the handle slabs.R.A.T. said:My bitch has always been with stop pins and pivot pins. If you can get those two parts of the equation more precise and better designed then a lot of the liner lock problems would go away.
Esav Benyamin said:I should have run through my knives before that last postThe Strider SnG also uses dual thumbstuds as blade stops, against radiused handle slab contact points.
Bob Dozier's tab lock is even better: it's a liner lock that contacts the full height of the tang, serving as lock and stop bar together.
Kevin Wilkins said:I've wondered how well the knives using the thumbstud (or similiar) and the frame of the knife as stop pin device would hold up to slinging the blade open? You should have more contact area but the frame is bound to be softer than the stubs so I wonder about battering damage to the frame. The amount of deformation doesnt need to be much to change the lockup of the knife. Do any of these knves have hardened insets in the fame at the contact point with the thunbstuds?
It comes up constantly on the tactical forums mainly for speed, and it has other applications for opening in other conditions where fine motor skills are not possible. Recently around here the temp has dropped and in such conditions manipulating thumbs studs and similar can be difficult, but its still readily possible to snap out a blade.Scott Dog said:Can someone give me a reasonable explanation as to why flipping open a folder is so important.
