- Feb 1, 2011
Question for those experienced with slipjoints.When blade is open and when closed.What position is the blade at when you're experiencing the movement
Did you buy it new ?When blade is open and when closed.
Oh ok that's a bummer.Yup directly from CK and not the discount pile either.
And they dont have any left of the wood ones so....
I'd wait until MikeYeah not happening. I will try and fix it myself. Besides i welcome challenges and love to fiddle and open my folders to see the inner workings.
Will do since u boys know much more than i do. Im a slipjoint newbie. Hopefully he will.
Can anyone verify screw sizes on these yet?
View attachment 753235 Question for those experienced with slipjoints.
Is it normal for blade play side to side (not up and down since its not locking). I received the roundhead and since its a barlow thought it would have been a bit tougher than normal slipjoints. Note i have removed the bolsters and adjusted/tightened as much as i could while still being able to open/close it.
Tried tightening more but became super diff to open and close.
Any info would be appreciated.
There is no way to know without having it back in hand to check. But I expect that you are trying way too hard to find the "play". One perceived issue I see with modern folks that are trying slipjoints for the first time, is that they don't even expect any flex and they call it side/side movement. If you are having to try and discern movement, it is normal for a slipjoint. I say this because you have found "play" in the closed position as well; that is a very strange test in a knife this size. If it actually has play, it would be a great anomaly in this run; if it has flex it would be like every other one.
Not all woods require stabilization; but applying poly has nothing to do with that. So once you have decided if the knife is "yours" or not - if you like an extra coat of poly protection I say go for it.
