Sal, The idea that steels can be placed in categories has a lot of merit. The ones you mentioned, S90V, CPM S110v, CPM S125V and the like always group together if edge holding is the criteria and with other variables as close to the same as possible. CPM 10V leads the pack but is not stainless so would probably be in a different group with CPM M4 and others. Another group might be CPM S30V, ELMAX, M390, D2 CPM 154... others I am sure will be suggested. D2 is not a full stainless so might fall somewhere else but you get the idea. All of these have pros and cons with ease of heat treat work ability finish quality, availabliity and cost for example. Another group might be 154CM, ATS34, N690, VG10 and so on. Others will have differences and their own candidates but in my experience it would kind of fall like that. Given these categories one can then select the best steel for the application. The application varies with the critera. For example if i want a stainless hunter, used for field dressing, skinning, and light cutting use, no prying or chopping I would go with CPM S90V or CPM S110V. If edge holding is the overriding criteria then CPM 10V or maybe M4 would be the answer. The best solution for a fillet knife or kitchen knife where corrosion resistance comes into play might be CPM S30V, ELMAX, CPM 154.
You are making a concentrated effort with your research -- the mules and the like- to characterize pretty much all the available steels and so to then be able to concentrate on the best steel for the application. The mule idea is great since you get feed back from a wide range of users and that can be compared to your own work,, CATRA testing being only one of the tools. The mule information is wide ranging and public. Your hard won internal testing is yours to use as you wish, you own it. I understand that and I think most hear do also. I know some will go crazy on the rankings above but they are just examples and are based on what my knives from my shop do based on my testing. Others will rank differently but as hard as I try I can't make a D2 blade cut better or longer than a 10V blade. D2 is a great steel and even has some advantages over CPM 10V or K294 (the Bohler version) but it is back to the best steel for the application. Phil
