Hey Noctis,
I'd like to learn more about this corn cutting.  Could you elaborate?
There's a good project for you Jim.
Develop a series of cuts on different materials and try to keep consistent.  I'm sure the performance bent afi's could help develop the tests.
Kinda like the cutting competition, but a consistent cycle that each edge/steel would be rated on.
sal
Well, I work in a produce department of a grocery store, and one of my tasks include trimming unnecessary parts of corn so that it looks more appealing, is easier to stack, and doesn't leave a mess all over the floor(customers will often husk the corn and leave a mess if you don't clean it beforehand).
The parts I remove are the stalk, some of the leaves, and the hair.  I typically hold my knife with the blade facing towards me and push the stalk of the corn towards the blade with my right thumb while simultaneously twisting the corn with my left hand.  Sometimes it isn't necessary to twist the corn with thinner blades like my Spyderco Endura FFG or my Spyderco Gayle Bradley which can push cut the stalk, but thicker blades like my ZT 0301 and BM 755 MPR will need that extra twist.  For the most part, the tip won't see much use with this type of cutting, and it can be done with a blade shorter than 3 inches.
During the process you can somewhat tell when the blade is getting dull because you can't take off all the hair with one forward slice, but the real test is on slicing paper.  For me, if it can't slice paper without tearing it, the knife no longer has a working edge.
I think the main causes of a dull edge with this kind of use is edge rolling and abrasion.  Steels with less than 60 Rc(S30V) tends to roll, while steels with little to no wear resistant carbides(CTS-XHP) will be worn away by the silicates in the stalk and leftover dirt.  Micro-chipping only seems to occur in especially brittle steels like ZDP-189.
			No other do not have defined testing protocol yet and did not isolate most factors.
You do not have test until you descibe what you are doing. So far you just sad you like this and don't like that because you cut some corn. This is not test results, until it is more clear what you are doing, how do you make sure that initial sharpness is same , what you use as a base. All what I asked you before.
So you are not tester - corn cutter may be, you need to make some effort to write about what are you doing. Then we may see what it is.
So far you just state thet you do not like CTS-XHP. Initially in first post you sad that it may be due to your sharpening, but now it is like fact of life. Sorry, information you provided so far is not enough to make any conclusion.
Thanks, Vassili.
Like Ankerson, it's mostly informal.  And rather than call it testing, I call it real world use.
I used my knife on the job, and I get the feeling my boss wouldn't allow me to take a video and post it on YouTube.
I'm not trying to say that CTS-XHP is bad, just that it isn't the choice for corn.  For most other kitchen uses(carrots, tomatoes, lettuce, celery) I'm sure it would do excellent.  Besides which, the data and Carpenter made no mention of the steel being wear resistant.
