A great way to show off some exceptional looking stag. Very nice, Randy.Here's my sodbuster recovered in stag by Glennbad.
Wow Glenn's found a stag honey hole, what a perfect fit! Just beautiful.
Got a recent mod here; a Kabar on barlow scales with a mystery wood. The customer wanted me to use the wood he made his dining room table out of years ago. Very hard and dense, I'm leaning towards ipe, it has the chracteristic yellow streaks through it:
Eric
always solid work from Glenn! my go to modder, wonder how his schedule is these days![]()
On this side of the scale, I ended up cracking the wood and tried to fill it in, but not such a good job.
Here is some file work that I did no the spring and the blade.
Side views closed.
Thanks Glenn.I like the file work! Good first attempt, keep it up.
Thanks EA42. Noted on the blade, I will stick to heating the spring and not touching the blade.That's darned god for a first attempt! One thing though, I would avoid heating the blades up like that, what happens is you destroy the temper and wind up with very soft steel, or worse very brittle steel. The goal is to keep the blades as cool as possible. The file work looks fantastic!
Actually you shouldn't heat the spring either. You'll un-spring it.Thanks EA42. Noted on the blade, I will stick to heating the spring and not touching the blade.
If you heat steel enough to give it color, then you've heated it enough to ruin the temper. The hotter it gets, the softer it gets.
This is just an approximation, but if you see yellow then you have met/exceeded blade tempering temperatures and if you see blue/purple then you have met/exceeded spring temperatures.
You can add that sort of coloration non-destructively through a patina. Different things turn the knife different colors. Red meat makes it more of a blue, fruits and vegetables make it more gray.
So could I theoretically just stick the blade into a steak that is sitting in the refrigerator for say an hour to get the desired color?
