Hey all. First of all - thanks all so much for the input and feedback. This post got way more responses than I ever imagined. Second this is the summary of my garage/totally non scientific test. In the end this is all really just back road drag racing. Its total flawed in every way, but honestly this is how most people get a feel for things.
1st test - Buck 112lw compared to a Delica 4 (Correction - saber ground. Thanks to all who mentioned that it was most likely saber). Both paper slicing sharp tested to making poor paper cuts.
2nd Test - Same Buck 112lw compared to a Delica Stainless (hollow ground - as luck had it I have one of these also. Its older but still great and still in vg10). Both paper slicing sharp tested to making poor paper cuts.
In both test the 112 was substantially more proficient and comfortable at cutting the cardboard throughout (Both the handle and the blade just seem to work better for this). The vast majority of the cardboard was the thick diaper box cardboard that is much thicker and tougher than your typical amazon box. Cuts were each done in a set of 5 cuts alternating between knives. In the end of both test the Delica in VG10 began to pull the paper and make poor cuts before the 112 in 420. The Delica also started to make poor cardboard cuts first also. End - Both were no where near as sharp as in the beginning, but the Delica was just making worse paper cuts starring to pull rather than cut. It is worth mentioned that the hollow grind delica did perform better than the saber.
Yes I know this test is totally flawed and it honestly started as just me trying something out. I had not intentions of sharing outside of getting an unexpected result and requesting feedback from BFs. There are 1000000 variables to why this could be.........but at the end of the day this is all just for fun.
My thoughts as to why this happens as VG10 should on paper be the better steel. I was really was more thoughtful the second time and took note of small differences in the cutting. Now this is going to be the super controversial part = I think its the Spyder hole. Although the Delicas best feature it kept hanging up on the cardboard and I would have to make another cut motion to get through the cardboard likely causing increased wear. The cardboard that is really ragged in the photo - that's all the Delica. The 112 would glide through with less effort and a single forward/back motion. Take what you want from this but this was my fun test. Both knives are great but the 112 for me performed better and is like $40 cheaper.
I will keep doing this for fun - but this will likely be my last post on this type of topic. People just get too invested in one side of the other. Thanks all.
https://imgur.com/a/mSA1hQZ
