A reason to be somewhat disappointed in Kizer. I guess it is obvious to any who have read this thread, that I have been pretty pro-Kizer to this point. I remain positive about the materials they are using and the knife's that they offer, but I am going to attach a series of e-mails here, to show why I am very disappointed in Kizer's stance on my second knife, the Ki3404 A2, while I like the appearance of this knife very much, as I have stated here before, it never did and still doesn't flip worth a darn. It is like the action is submerged in molasses. As I also discussed in this thread, I disassembled the knife, and polished the washers. In short as you will see if you read on, this voided any warranty with Kizer. The dealer I purchased the knife from has said as much also, but in the e-mails I will post, you see it straight from David, the fellow who posts here on behalf of Kizer. In addition to these e-mails, I sent him on other, which summarizes the fact that I am very unhappy with their resolution to my issue. Basically at this time, a few days after I told David/Kizer I would wait before posting their response, I am left to resolve this issue on my own. The exchange follows:
Hi, Don:
I spoke with the engineering team regarding your situation.
The current conclusion is that this is not a defect in the manufacturing process or a defect in material (i.e. lock failing or inclusion in material). At this time, we would recommend using a different type of lubricant such as nano-lube/nano-oil that may improve the feeling of the action.
If you were to send it in, we would not be able to "tune" the knife other than to return it to the factory spec and tolerance. However, since the knife has been disassembled and work performed on it, the warranty would not apply in this case and you would be responsible for shipping cost to China (where the factory is located) and back (our CA warehouse is currently only qualified for warranty swap and not repairs).
I apologize for the inconvenience this issue has cost you, please let me know how you would like to proceed.
Thank you.
David.
-----原始邮件-----
发件人:"Don Davis" <dinks@windstream.net>
发送时间:2014-03-12 08:14:28 (星期三
收件人: "kizer@tbt-gd.com" <kizer@tbt-gd.com>
抄送:
主题: Re: Ki 3404A2
Hey David, I hadn't heard from you and I wanted to just follow up on my knife.
Thanks--Don Davis
Sent from my iPhone
On Mar 6, 2014, at 4:18 PM,
kizer@tbt-gd.com wrote:
Hi, Don:
I'm sorry to hear the knife did not perform to your satisfaction.
Usually in cases like this, we would recommend contacting the dealer as your first choice due to it would be faster for the user. However, since the knife has been dis-assembled and worked on, I'm not sure that would be an option at this time.
Let me consult with our teams to see, in this case, how we can be of help.
Thank you.
David
-----原始邮件-----
发件人:dinks@windstream.net
发送时间:2014-03-06 05:35:49 (星期四
收件人:
kizer@tbt-gd.com
抄送:
主题: Ki 3404A2
Hello David, I think. My name is Don Davis, I post on Blade Forums as Fish30114. I have recently purchased two Kizer knives, and started a thread on Blade Forums titled My First Kizer I found this e-mail address in a reply to one to the posts in that thread. Long story short, I like both of my blades a lot in general. The liner lock, the 412 A2 I have no issues with. The second knife I bought is the 304 A2 and although I like the knife OK in general, it doesnt flip well at all. If I loosen up the pivot where the knife is sloppy loose nearly, it still doesnt flip well, and the blade centering goes to pot. I have taken the knife apart and polished the copper colored washers, still to no avail. I would like your guidance on how to approach this issue, as it is I am nowhere near satisfied with this knife as is. I like the styling and appearance and apparent fit and finish save this one factor, which is a key one obviously. I look forward to hearing from you, my contact info is:
Don Davis
So, as a cautionary tale, to all you fellow blade enthusiasts, beware disassembling your Kizer, even if it is such mundane stuff such as cleaning it, or as in my case, that and polishing the washers--which didn't cure my issue BTW. I say possibly a reason to be disappointed in Kizer, because, I actually think that naively, Kizer and others make the assumption that if disassembled, the knife must get fouled up by the owner--I obviously don't agree with that, but I am not sure that is the wrong position for a mfg. to take. In my final reply to Kizer, I state my position, which is, that if a knife is found to have had improper maintenance performed on it by it's owner, or other issues caused by the owner, that is one thing and possibly worthy of voiding all warranty, but for many mfgs. such as Kershaw, they have even sent me replacement parts of maintenance and even repair of some of the knives I own from them. (other mfgs have done the same) So in closing, I would ask for advice, and tips on how I might get this knife to start to flip decently. I have thought of obtaining some washers from a source other than Kizer (since they are not going to help past this point) or sanding the washers in the knife down a bit--other suggestions are welcome. And BTW, for those of you that have posted here that you have disassembled your knife, even if just to clean, or polish the washers, such as I did, be prepared that you no longer have a warranty from Kizer, if you disclose that fact.
