... what a truly thin and acute ground knife can do ....
Hopefully I will actually have a sensible steel for that grind shortly, SPGS is far better than CPM154 or similar, but ideally you use steels like W1, hardened so as to produce minimal retained austenite and martensite needle size while maximizing hardness. It is too bad you can't do all three of them at the same time, that is the problem with steels, for everything you increase there are a dozen things you decrease at the same time.
This is already in progress with three customs so designed, several more batches planned, including one in A2 which is of personal interest because what I have seen of its performance described (Elliott, Beach) makes no sense given its material properties (which indicate high edge stability). My personal favorite; 1095 vs F2 vs M2 vs 13C26 vs [some fad underhardened high carbide sillyness].
...using the term “horrible misuse” of 13C26 in regards to Kershaw, IMHO is a statement that is way off base.
You are using the steel exactly opposite as it is designed which makes its weakest property the critical performance element and its greatest property is irrelevant so yes, that would be horrible misuse.
We recently changed the Storms over from being flat ground to a hollow grind.
That isn't even relevant to what is being discussed.
Personally, I'm hoping to see a manufacturer step up to the plate with a very thin and high hardness design in that steel...
Yeah, use the steel as it was intended to be used, really not something that you should have to ask for.
Hi, Thomas ... wanted to say this is the kind of thing I like to hear from a manufacturer.
You are pretty easy to please. I want actual facts and logic not vague claims of research with no details and vague promises of improvement. What exactly were your design goals, how exactly were they achieved by the implementation. If you are improving then what is the direction and how is it implemented. Are you using research groups, how exactly are you dealing with personal bias in sampling.
As an example of what I want to see, this was a conversation I had awhile back with a knife maker :
"Why do you use that steel?"
"We spent a lot of time working with that class of blades for heavy use of various types and it was found that most blunting took place by fracture and/or deformation, there was little evidence of wear so we looking primarily for high toughness."
"How did you determine that."
"Magnification."
"Do you have any pictures."
"No, a lot of it was done with loupes and such."
"How extensive was the damage."
"It depends on the steel, it was visible in some case and others just visible under light magnification."
"So what are you aiming for?"
"Not visisble at all by eye or even under light magnification, no roughness to the thumbnail for example."
"So what about the wear resistance?"
"Yeah, that is low compared to some steels, but quite frankly it is still so high it isn't an issue."
"Who did the work?"
"I did and a bunch of friends."
"How did you make sure you were getting honest feedback?"
"I didn't, that's a real problem."
"So you are there now?"
"Huge improvements from where we started, the best I have seen personally, but still not satisfied and working with the heat treatment and exploring other steels essentially trying to find the best mix of hardness and toughness."
Note a clear description of the exact performance goals and how they were achieved. This was followed by an indepth discussion of the heat treating which wasn't "we are doing a good job" but specifics on what was used with again the same type of details. That is what I want to see from a manufacturer. Everyone says they are superior, everyone says they are improving, everyone says they did lots of research. I want an actual logical arguement supported by facts.
-Cliff
