I sanded the handle down on mine with some wet/dry sandpaper. I think it helped. A convex edge would also really aid in the performance of the knife.
Great knife. I really like mine.
that's a grat score on a great knife, very handydesign.
Steel-Junky, you don't need alot to maintain a convex edge, just a simple piece of leather or sandpaper, you don't need the compounds to maintain the edge, heck a piece of heavy cardboard will do the trick
The coating will come off... I've never been a big fan of convex edges though. I like something I can sharpen with just my ceramic sticks in the field. If I'm not mistaken you gotta strop a convex edge with varying grits of media. Too much gear to drag around.
You can strop on cardboard, a belt, your jeans and other things. Flitz or other metal polishes work fine. All the high dollar gear is not necessary to maintain a convex edge.
Wonder why most Busse's come with such a lackluster edge??
I mean I get that with a big chopping blade you don't want a fine edge that will mess up when you slam it into some oak or something.
On the other hand stuff like the Game Warden, or the BAD or that SAR, those sizes are really using knives.
The BAD is about the same overall size as the Fallkniven F1, maybe a bit smaller. The SAR is about the size of the Fallkniven S1 correct? Both of those are significantly cheaper but about 10 times the effort at the factory seems to have gone into the edge on them
I have a Game Warden and it's around the size of a Bark River Mini North Star but while the Mini North Star has a really great edge it took me hours of work to put a decent edge on my Game Warden which cost twice the price??![]()
I have seen stripped busses before, I think....really not sure.
Once you get the edge convexed and sharp, you only need 1 grit to maintain it. I like to strop my knives with 2000 grit after every use. I never let my knives get dull to the point I need more than that.
People mistaken think that a thick blade cannot cut efficiently. I think some of this is ignorance on the users part. Geometry is a great deal of it. On a Busse there is a lot of material right behind the edge....
Very true. I have to pay way more attention to angle sharpening a v grind or scandi than a convex.
A film container or ziplock with a few strips of 600 grit sandpaper and then just lay them on your knife sheath or any semi soft surface and strop and that is all you need for field sharpening.
Right. That causes a drag for me when I'm cutting something just like coating does.:thumbdn:
That seems to have an accidental similarity to the below offering from Tops. I wonder which came first.
I care for neither company but I'll admit I did think the Busse below looked like a practical handful. Vivi thinned it out and convexed it. As depicted it is the most useful looking knife I've seen from that stable.
If you are chopping or batoning and hit a rock and nick the blade, which I have done a few times, I have never screwed one up bad enough that I couldnt strop it out with 600 grit fairly quickly.
cool, I will say that I don't have years of experience with convex edges. I would figure that in a serious edge deformation it would be hard to strop out. I know the convex edge is VERY strong... I've just never been confident that it was easy to repair under a serious deformation. I'll look into it a little further... maybe get me a fallkniven or something to test it out... don't wanna convex a Busse until I'm sure I can deal with it in bad sitautions easily.
With very serious edge damage, im sure a convex would take a bit to fix by hand. However, I have found it to be an extremely durable edge, that takes regular use, and some not so regular very well, so well, that I havent had a problem as of yet. Plus Busses heat treat is insanely awesome, and makes for a very tough convex edge.
Heres some pics of my BATAC I stripped, scotchbrited, and convexed. It took a long time to convex, but I did it all by hand, no power tools used on it at all. I also squared the spine up nice by hand so it strikes a ferro rod very well. :thumbup: I started with 180 on the edge and spine and moved up to 220, 600, 1000, and finished up with 2000.
