Steel-Junky
Banned
- Jan 15, 2009
I'm not going to argue with you, as you're clearly set in your ways. I'm just going to point out the irony in saying I'm spreading misinformation when I say a thin edge carves better than a thick one (and suggesting people have come to this conclusion due to ignorance) then in the same paragraph admit a "beefy edge" will preform poorly at carving.:jerkit:
That's not what you said... You said "A thick edge can be razor sharp, and slice paper very well, but for cutting other things like wood, geometry is as important as being sharpness. The larger the angle the farther away the spine has to be held from what ever youre cutting, and that affects performance." This is not the same thing as saying "a thin edge carves better than a thick one". I would have agreed with that. You implied that a thick edge was not good for cutting material like wood... this is simply a work of fiction. A Thick edge works very well at CUTTING wood. It is however poor at finely carving it. And I agreed with that. But the chores that being able to finely carve wood are useful in are not very useful to me. Making fine little wood carvings don't matter to me. I don't NEED to be able to make a spoon, or a bowl, or pipe, or a wooden duck, or a candle holder, or a civil war soldier figurine. I need to be able to cut wood (not whitle it [Spelling]), I need to be able to notch wood, split it, chip it, make shavings, strip it, and quarter it... and a thicker edge geometry does this just fine all day long. It also works well at cleaning game and breaking bone, and a beefier blade which would support a thicker edge has a million an one uses that a little thin whispy blade does not. So if you're going to argue the finer points of the pros and cons of thin vs thick edge geometries... at least get right the statement you're trying to make. Because implying that a thicker edge cannot cut wood well is simply false.
