See what I don't get is how you always pick the right letter pattern...09/19/2022: Wordle 457 3/6
4 letters revealed in w/my 2 starter words
with at least 5 possible solutions based on
the lettern pattern that I chose.
I used my "most obscure word rule" to make
the 3rd guess which fortunately was correct.
Threre was also 1 other possibility using
a different letter pattern that I fortunately
didi not consider.
The current NYT average for this puzzle is 4.2.
09/18/2022: Wordle 456 4/6 STICK
7 different possibilities but only 2 based on the letter
pattern I chose and, of course, I chose the "wrong"
word 1st. Oh well . . .
The final NYT average for this puzzle was 3.6.
Wow you cut that one close!Wordle 457 6/6*
I switched to hard mode so I can't do throwaway words anymore, but thanks for the tips!I can't really answer that but, as in this puzzle, there is almost always a letter pattern that is the most obvious and/or likely to lead to the solution
I wasn't the only 1 that chose the "right one" in this case. You apparently chose it too.
The only problem was how to reduce the possibilities which, in this case, required me to identify all of the likely words and then choose the one I considered the most "obscure"because I think that this is an inherent bias that the designer built into the game in order to make it more "challenging."
See, for example: Wordle Prototype Word List Contained Extremely Obscure Words
Here are also a couple of links to sites that describe some of the techniques that I use in choosing a letter pattern and analyzing a puzzle:
1) Use This Wordle Strategy To Win Every Time
I use very similar strategies for each guess as suggested in this link.
2) I've Played Every Wordle & Lost Only Once -- Here Are My Tips
There are 10 "tips" offered in this link. I use all of them in 1 way or another. Tip #2 is more a goal than a tip - "protect your streak" and avoid failure by any means possible. The rest are solid strategies for choosing a letter pattern and analyzing a puzzle.
The author of this link probably would have used a "throw away" word to try to reduce the possibilities in today's puzzle based on his Tips #2 & 3.
Good luck!
