The 'newer' 119 and 102 use 420HC, which is easier to sharpen than 440C, but not THAT much easier.
Regards,
3G
440C is very similar for resharpening as 420 HC.
Regards,
3G
True, but if you try to write "review " you must have facts about it.
Picture shows also lenght of blade ( actually shortness of blade ).
Indeed! And 1095 is as easy, if not easier, to sharpen.
Regards,
3G
what about it? the point was on the lenght of the handle. youv'e moved your hand back, are still getting a good grip on the knife (far as I can tell from the picture) and don't have your fingers on the blade.
edit: ahh, I see what you where doing in one of your erlier pictures. the hollowed out part between the actual blade and the guard isn't intended as a notch for your foward finger, I'ts intended to allow you to sharpen the whole blade properly, rather than having problems sharpening (and using) the full blade as anything right at the bottom hits the handle scales.
No. Design of handle and blade is poor and because of that you have poor grip on a handle and poor blade lenght
so far your pictures have shown no actual evidence of the grip being poor, and even then this only suggests that the design doesn't suit you, with no supporting information on stuff like how big your hands are. if you have larger than average hands, some knives may have grips that are too small for you, because they are based around an average hand size.
I have large hands myself, and find short handles work fine, since palming the handle is a legitimate and comfortable grip that gives me good control, especially with a short blade.
Only for heavy chopping with a longer blade would I prefer a handle overlapping my grip, especially with a bird's-beak.
(By the way, the proper spelling is "length."
the blade lenght is not affected by how the handle is designed. and what are you using it for that needs a longer blade. I can do most jobs I come across with a modified disection scalple (the one peice type) I don't, because that realy does have an uncomfortable handle. but it is possible. blade lenght is about the same as the small blade on a swiss army knife. a blade the lenght of a standard swiss army knife blade could do almost any job apart from chopping in my experience. so long as it was wide (edge to spine dimension) enough
RAT has has short handle but that wouldn't be such problem that is better designed ( shaped for more confortable and secure grip ).
right. you'r problem is with the shaping of the handle. not it's length. if you'd said that at the start, then things would have been far easier.
also, a word of friendly advice: constructive critisim is prefered to simply slagging a knife off. what are its good points? what are its bad points? spesifcs on problems are good, as are sugestions for how those problems might be dealt with.
What do you think who resharpend this knives? I did it with Lansky sharpeners ( diamnond and regular, all grains ) and it last for both knives 6 - 8 hours till knives were razor sharp. For example, i resharpend Buck 119 to razor sharpness for about half hour. Steel 1095 will rust in salt and jungle enviorment because of his structure and canvas micarta already shows changes on surface ( in " kitchen enviorment "). You should get some experience in " wine and cheese ". " Yes - no " doesn't proof anything.
Please, try resharpen dull 1095 knife.
I forgot something important!
Sheaths do melt very easy, burn easy so beware if you sit close to camp fire. Even with tek lock, knife would be easy to lose in outdoors, especially in extreme situation. Very weak sheath with much possibilities to carry and lose knife.
I must also reshaped entry of sheath how it can be easier to hold handle.
