I have one and I will say it is an absolute beast of a folder. It makes Hinderers and Striders look like they are made out of paper. It feels very sturdy (while it still is a liner lock) like a knife that you could definitely do some prying with.
Ñ
Note that it has kjnd of a strange build where they stack a bunch of thinner steel sheets in order to build the knife up so I doubt it is a knife you would want fk take apart. However you could take the blade out by undoing the pivot. I jusf wouldn’t attempt disassembly beyond that.
I don’t know if you can see it well but notice it has double liners on one side and the “backspacer is actually made of three plates of steel the same thickness as the liners.
This thread is yet another reminder of how readily we stray into knife theory nitpicking. If we were to listen to every piece of internet commentary, no chunky blade would cut anything, blade stock under .10” would snap readily, folders without jimping would slip out of hands like wet soap, nobody except Demko would have fingers due to lock failures, Benchmade folders would ship with blades standing out 90 degrees to one side of the handle, ZTs would sever entire hands by failing while bludgeoning bananas, etc.
You win this thread !
Adamas compared to a 3.5 XM. Damn this thing is comically big
Is one side thicker than the other? I don't think I've ever seen a knife designed that way.
Here's another fun Adamas comparison, the Microtech Socom Elite. It might be hard to tell, but the Socom has a thicker blade than the Adamas and its handle is almost as thick at the ends (thinner by comparison in the center, though, because of the swell/contour on the Adamas). It's a different kind of tank.
(I think an argument could be made for the Socom Elite being overbuilt given the thickness of the blade stock, but it's such a relatively light knife thanks to the aluminum, and slim in pocket thanks to its handle design, that it doesn't feel overbuilt.)
Exactly, as strong as their weakest point which is the thin lockbar cutout, and that fact that when dirty and greasy even well made framelocks tend to slip in my experience. In my opinion as far as strength goes the last 2 are in a whole new league then any axis or framelock. Do we need folders this strong? not really but if they can also cut well I like them and I pair them up with a GEC slip when I need a a thin blade for deeper cutting.Overbuilt folder? Sometimes they are cool...
However I think it is completely possible to make a tough knife without making it “overbuilt.” Sebenzas are virtually indestructible but aren’t overbuilt.
Then there is the fact that most of these overbuilt ti framelocks have their lockbar cutout be quite thin. So what is all that thick titanium good for if it will just fail where it is thinnest.
The OP asked yes or no
Some have said yes some have said no
No one is right no one is wrong
Heck I edc a small fixed blade most days
Does not mean that that is the best choice for all
I’ve been involved in knives for decades and I’ve seen fads come and go
The overbuilt genre I do believe is here to stay but it does not mean they are for everyone
My biggest issue is with overbuilt frame locks
They just don’t add up
Depending on the geometry of the lock face, if the angle is steep like Medford for example the early lock up with a steep angle makes it easy to slip and close.Early lockup is strong lockup, the closer to parallel the lockbar stays the more direct force it is able to resist without deforming. Late lockup only means you have to push the lockbar further before it can close.
Is that an automatic? If so, it’s probably the stoutest blade on an auto.
One side is thicker making the knife asymetric. Some other asymetric knives are Spyderco Southard, some trevor Burger customs, which are linerlocks with only one liner.
Is there a need for a folders handle to be symmetrical? I was just using my zt 0562 and noticed that the cf/steel side of the handle is slightly thinner than the Ti side.
