Hi all,
Thought I'd check in and share my experience with the paper wheels. Before I do, a big thank you goes out to the OP, richard j, for single-handedly getting so many people to try this knife sharpening system with good results. About myself, although I do enjoy and appreciate just about any edged tool, I make no pretensions of being an expert or even knowledgeable about them and much less when it comes to sharpening. My one and only sharpening system is a Sharpmaker that was purchased about 10 years ago. I found, as many have, that it's a great system to keep a sharp knife sharp, but not that good for knives that need a good bit of material removed.
Before I stumbled onto this thread, I convinced myself that I needed to get a belt grinder setup so I bought a Harbor Freight 1x30 belt grinder and a bunch of belts. I was going to learn how to sharpen blades with an old 20" or so Collins machete. The blade had a few chips in it and the only sharpening I've ever done on it was using a 6" bench grinder and then later on a v-shaped carbide sharpener that you pull across the blade. While I was waiting for the additional sanding belts to arrive, I tried repairing the edge with the one 180 grit belt that came with the belt grinder. I got discouraged after a while when it seemed like I just couldn't remove enough material to get rid of the chips in the edge. That's when I came across this thread, read all 50+ pages and really wanted to try it. I went with the Porter Cable 6" variable speed grinder and reversed it because I feel more comfortable with the wheels turning away from me. Once I got it all set up, I tried sharpening that machete again. Again, I just couldn't remove this one chip about 5" from the tip. So I broke out the HF 1x30 belt sander and sanded away with that 180 grit belt and finally removed the chip and put a convex edge on it. As per richard j's suggestion in this thread, I went to the buffing wheel and now that machete is so much sharper than it ever has been. It slices newspaper very nicely.
Next up was our Chicago Cutlery knife set that we've had for 20 years. My wife messed up two of the thin blade knives in her attempts to sharpen them with the steel. It appears that she was running one spot on the blade down the length of the steel so there was a 1" area in the middle of the blade that looked like three serrations. I took my time and was able to remove the damage and this knife set is now sharper than it ever has been. I had to stop feeding my Rottweiler raw chicken because I couldn't get my knives sharp enough to cut raw chicken easily. It was taking too long and I was getting blisters on my hand from cutting 10-15 lbs of meat at a time. I am really happy to say that my dog is back on a raw diet and it takes less than half the time now to cut up raw meat. On top of that, the knife I'm using, a Chicago Cutlery stainless santoku, not only slices through skin and chops bones easily, but holds its edge much longer than ever. I usually prepare about 10-15 lbs of meat at a time so I will have about 4 meals prepared. So far I have done that process three times and the edge is holding up without even running the steel on it. In fact, I'm going to skip the steel and maintain the edge on the buffer wheel before the next feeding.
For my purposes, All of my sharpening needs are going to be met with the paper wheels, HF 1x30 belt grinder, and Sharpmaker. I still like the way the Sharpmaker sharpens serrated edges and I can even use it to sharpen peelers.
So anyone who is a novice and on the fence about the paper wheels, I say go for it. For about $100 for the wheels and grinder, you will get a system that is easy and quick to learn. I am nowhere near mastering this system, but have gotten great results (to me) so far. All I know is that I am going to get better results the more I use it and that's pretty hard to beat.
