Okay, here goes Report #2 on the Salsa. I've been traveling the last couple of days, so the Salsa stayed home. No sense screwing up the pass-along project by having the Salsa confiscated by airport security
I should be able to give the Salsa a good workout this weekend. We're ripping up the nasty carpet in our kitchen and putting down tile. We'll see how the AUS8 holds up to linoleum cutting (I'll also try my Sebenza just for yucks).
More ergonomic observations:
The Cobra Hood is kind of cool, but really detracts from the usually sleek Spyderco lines. It works pretty well, though. I suspect that it would work just as well at half its current width. I've never really had a problem getting the standard Spyderhole to work, so the ridge around the outside is just gravy. It wouldn't take much to get the same effect as the wide hood. And, frankly Cobra Hood is kind of overwrought for my taste. How 'bout Prepuce(tm) instead?
The Salsa sticks quite far out of the pocket when its clipped in -- looks like a little over an inch above the pocket seam of jeans. Very conspicuous, especially in dress slacks. The Salsa is nowhere near as discreet as the Lum Chinese or small Sebenza that are my usual EDCs.
I dressed the blade with the fine stones of the Sharpmaker the other day. The AUS8 steel takes a very nice edge very quickly. It took about 40 strokes per side on the corners and another 20 per side on the flats to get rid of the burr/ding on the belly of the blade and put a nicely sharp, grabby edge on it. This is just about perfect for a knife that'll be used for a wide variety of every day cutting chores along with a limited amount of heavy duty cutting.
I'm still having a hard time getting used to the width of this sucker. With the Salsa clipped to my right jeans pocket I can't even get my keys past it and into my pocket -- it's just too wide.
Compression Lock: I like it. I haven't had any problems opening or closing the knife one-handing or experienced any pinching or soreness as others have reporter. It does
look a tad flimsy, though. I know it works. I know it's strong. But the little tang (prong? piece?) of metal extending from the compression insert (the lock bar thingie) just looks too small. I know it's extremely unlikely that piece of metal will ever fail, and the Salsa's done great in the spine-whack test, but I'd make it bigger (taller) for the visual effect alone. Dunno, maybe it's just resistance to a new idea.
That's all for now. I'll let y'all know how this weekend's flooring project goes. That'll be the hard-use test. Then I'll clean it up and pass it along to the next person.
Chad
